Fairlightiii Posted September 5, 2012 Posted September 5, 2012 Hi everybody. Is there someone which know the exact dimension between the drill holes of SmashTV core R4, LTC and DIN modules? The layouts are differents than the *.brd of TK. I could take a rule and do it myself but the result won't be so precise than the *.brd itself. I sent an email to Tim but he must be busy now. Thank you.
Fairlightiii Posted September 7, 2012 Author Posted September 7, 2012 Some answers in 2005 (no information about drill holes): I need to gather more info but I will be including the pcb sizing/mounting hole info on my pages soon..... Quick answer for the question: Material FR-4 Thickness(inch) 0.062"Â Copper Weight 1 (oz) Pad Finish HASL COREr3, SIDr2 = 82.000x64.000 (mm) AINr2, DINr2, DOUTr2, JDMr2 = 100.000x45.000 (mm) LTCr2 = 64.000x48.000 (mm) OPL3r1 = 100.000x65.000 (mm) MFr1 = 88.000x64.000 (mm) best Smash
rosch Posted September 7, 2012 Posted September 7, 2012 i have none of the boards you're asking from smash. i could measure the hole distance to the corner on the MB6582, SeqV4, SeqV4L or Aout_NG if you like, but i have no idea if they're all the same.
Fairlightiii Posted September 8, 2012 Author Posted September 8, 2012 Hi Rosh. but i have no idea if they're all the same I would'nt bet on that. I've found more or less between the holes with my rule: Core8 r4: 7.2mm and 5.4mm. LTC r2: 5.55mm and 4.05mm. ...It's not easy with populated modules. As holes seem to be 4mm and I will use M3 screw, it should be ok with my "eyes precision".
latigid on Posted January 3, 2016 Posted January 3, 2016 (edited) For any past or future travellers, I measured the DIN and DOUT r5 boards (just one example of each): DIN 100.1*45.2 mm DOUT 100.25*45.1 mm Thickness is about 1.6-1.8 mm. Both boards have exactly the some mounting hole positions relative to each other, i.e. does not rely on the outer milling. 4.3mm (prepared for M4 screws) centres using the x,y centre of the PCB as the origin with the long axis horizontal: (x,y) = (-45.525,-18.01) (-45.525,+18.01) (+45.525,-18.01) (+45.525,+18.01) Edited January 7, 2016 by latigid on
