Triffki Posted October 13, 2012 Report Share Posted October 13, 2012 Hi all, I've been following the tutorial here: http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac to set up Xcode 3. I got as far as creating a new project and then I got lost. I've downloaded mios_base_v1_1 from the downloads section on ucApps and found the SDCC skeleton files within it under 'apps'. Am I supposed to drag these files into the new project in Xcode? Also, the tutorial mentions the MAKEFILE.SPEC but I could not find this within mios_base_v1_1 Thanks Quote Link to comment Share on other sites More sharing options...
EsotericLabs Posted October 13, 2012 Report Share Posted October 13, 2012 If you're working with Xcode 4, some steps are here There are also posts on older Xcode versions. Quote Link to comment Share on other sites More sharing options...
Triffki Posted October 16, 2012 Author Report Share Posted October 16, 2012 Thanks for the advice. I've made some progress, managed to get up to the application building stage now. I get this error when trying to build: "sh: /mios-gpasm: No such file or directory" I've checked that sdcc and gpasm are up and running by typing "sdcc -v" etc. in Terminal. My sdcc is version is 2.6, and gpasm is 0.13.4 I've also checked the usr/local/bin folder to check gpasm and sdcc are in there, which they are Any advice would be appreciated I'm running Xcode 3 by the way Quote Link to comment Share on other sites More sharing options...
EsotericLabs Posted October 18, 2012 Report Share Posted October 18, 2012 Do you have the mios toolchain installed? http://www.midibox.org/dokuwiki/doku.php?id=macos_mios32_toolchain_core I don t think sdcc is still needed with newer macs. The tool chain uses the compiler gcc. I got the same type of errors when my environment settings were not correct. Do you compile and build within Xcode? Then you must add " export PATH= /path to mios_toolchain/bin:$PATH " to your run script. Hope this helps, otherwise post or pm me. Quote Link to comment Share on other sites More sharing options...
