folly Posted October 14, 2012 Posted October 14, 2012 Hello! Greetings to all users MIDIBOX. I need your help! I realizate the project MIDIBOX_KB buying the pcb by SMART-Tv MBHP_CORE_LPC17 and MBHP_DIO_MATRIX. I used a keyboard FATAR TP8/SK 76-KEY but does not work well, you transpone of 5 notes. C = G # I wanted to know if possibile use of midibox_kb Thank you!
TK. Posted October 14, 2012 Posted October 14, 2012 Hi, which note_offset did you specify? The first note can be adjusted with this parameter. Best Regards, Thorsten.
folly Posted October 14, 2012 Author Posted October 14, 2012 Hi, which note_offset did you specify? The first note can be adjusted with this parameter. Best Regards, Thorsten. thanks for your answer. pressing the C note, I feel the G #. the last 4 notes right, do not play. MK9 is BR9 not know where to connect them on MBHP_DIO MATRIX. of your schematics are in the air. Best Regards, Silviu.
TK. Posted October 14, 2012 Posted October 14, 2012 Could you please enter "kb 1" in MIOS terminal, and copy&paste the output to this thread? MK9/BK9: I would expect this only for the 88 key type... however, this schematic shows the required connections: http://www.ucapps.de/midibox_kb/midibox_kb_fatar_df_88_interconnections.pdf Best Regards, Thorsten.
folly Posted October 14, 2012 Author Posted October 14, 2012 Could you please enter "kb 1" in MIOS terminal, and copy&paste the output to this thread? MK9/BK9: I would expect this only for the 88 key type... however, this schematic shows the required connections: http://www.ucapps.de/midibox_kb/midibox_kb_fatar_df_88_interconnections.pdf Best Regards, Thorsten. hi! [46844.806] kb 1 debug off [46844.806] kb 1 midi_ports 0x1011 [46844.806] kb 1 midi_chn 1 [46844.806] kb 1 note_offset 36 [46844.806] kb 1 rows 8 [46844.806] kb 1 velocity on [46844.806] kb 1 optimized off [46844.806] kb 1 dout_sr1 1 [46844.807] kb 1 dout_sr2 2 [46844.807] kb 1 din_sr1 1 [46844.807] kb 1 din_sr2 2 [46844.807] kb 1 din_key_offset 32 [46844.807] kb 1 din_inverted off [46844.807] kb 1 break_inverted off [46844.807] kb 1 delay_fastest 100 [46844.809] kb 1 delay_slowest 2000 [46844.809] kb 1 ain_pitchwheel off [46844.809] kb 1 ctrl_pitchwheel 128 (PitchBend) [46844.809] kb 1 ain_modwheel off [46844.809] kb 1 ctrl_modwheel 1 (CC) NB. my keyboard it FATAR 76 KEY. THANK!
folly Posted October 15, 2012 Author Posted October 15, 2012 HI! I solved this way: [56797.983] kb 1 [56797.984] kb 1 debug off [56797.984] kb 1 midi_ports 0x1011 [56797.984] kb 1 midi_chn 1 [56797.984] kb 1 note_offset 28 [56797.984] kb 1 rows 16 [56797.985] kb 1 velocity on [56797.985] kb 1 optimized off [56797.985] kb 1 dout_sr1 1 [56797.985] kb 1 dout_sr2 2 [56797.986] kb 1 din_sr1 1 [56797.986] kb 1 din_sr2 2 [56797.986] kb 1 din_key_offset 32 [56797.986] kb 1 din_inverted off [56797.986] kb 1 break_inverted off [56797.986] kb 1 delay_fastest 100 [56797.986] kb 1 delay_slowest 2000 [56797.988] kb 1 ain_pitchwheel off [56797.988] kb 1 ctrl_pitchwheel 128 (PitchBend) [56797.988] kb 1 ain_modwheel off [56797.988] kb 1 ctrl_modwheel 1 (CC) for the last 4 notes E-6 F-6 F # 6 G-6 i solved by welding 2 wires. view photos attachments. Thank you for this beautiful project, congratulations! look aftertouch option for the future! thank!
TK. Posted October 15, 2012 Posted October 15, 2012 Thank you very much for the input! :) I updated the schematic: http://www.ucapps.de/midibox_kb/midibox_kb_fatar_df_76_interconnections.pdf And I changed the specification for the recommended parameters at http://www.ucapps.de/midibox_kb.html Could you please check if following changes are working ok at your side: set kb 1 rows 12 set kb 1 optimized on [/code] Best Regards, Thorsten.
nlate Posted October 16, 2012 Posted October 16, 2012 (edited) Dear Thorsten, Thank you very much for the input! :) I updated the schematic: http://www.ucapps.de...connections.pdf Could you please also check/correct the:Fatar DF88 interconnections The interconnections between left & right side 20-Pin MicroMatch connectors seem to be incorrect. Imho it should be: Green lines (MKx): J3,O7 -> MK0 -> MK5 J3,O5 -> MK1 -> MK6 J3,O3 -> MK2 -> MK7 J3,O1 -> MK3 -> MK8 J4,O7 -> MK4 -> MK9 (already correct) J4,O5 --------> MK10 (already correct) Red lines (BKx): J3,O6 -> BK0 -> BK5 J3,O4 -> BK1 -> BK6 J3,O2 -> BK2 -> BK7 J3,O0 -> BK3 -> BK8 J4,O6 -> BK4 -> BK9 (already correct) J4,O4 --------> BK10 (already correct) Thanks for the fantastic KB project! Best Regards Jo Edited October 16, 2012 by nlate
folly Posted November 29, 2012 Author Posted November 29, 2012 HI!I need to connect an encoder dialer on MIDIBOX kb. how do you? THANK!!
