Rear panel file?
julianf
thats for the STM core, not the current LPC one although it should be spaced the same and should fit if you didnt use the magjack. PM your email and I'll send you my files, I just did a SEQV4 based on the LPC core and the 4xIIC modules. I also used the dummy slot in the 4xIIC module as a DINSYNC port..
Here they are: LPC17 layout
The way this is designed to be mounted is via 2-56 threaded screws and the midi sockets that have 3 holes in them (CUI SDS-50J. The screws tap into the connector and it looks sharp. Obviously they can be omitted if the boards will be on standoffs. I also included a hole for the dummy midi socket on the IIc board to be used for dinsync
Edited by Altitude
