zephyrin Posted November 22, 2012 Posted November 22, 2012 Hello I wanted to know if i can used BPM Display 7 segments with 4 digits with the MB808 as the MBSEQ V4 ?
Hawkeye Posted November 22, 2012 Posted November 22, 2012 (edited) Hey there, if your 808 sequencer is based on the SEQ V4... yes, you can - you need two free DOUT shift registers to display the BPM digits, these shift registers also allow you to add a "current step number" display with three seven-segment digits. Here is a short demo video, you see it in action in the lower right part of the screen... Edit: sorry, just realized, that you are probably referring to the official MB808 - this one is SEQ V3 based and uses the old 8-bit core, I think a three-digit BPM indication should be no problem with it, four digits would require a firmware modification. Many greets, Peter Edited November 22, 2012 by Hawkeye
zephyrin Posted November 23, 2012 Author Posted November 23, 2012 Hi think for your answer Peter. I just look quickly the source, i think it's not so easy. i m suspect that the BPM is just calculate with only 3 digits.
Hawkeye Posted November 23, 2012 Posted November 23, 2012 Yes, while it surely is possible, it probably is not worth the effort :) I just wanted to have the fourth digit in the SEQ V4 because of bling reasons, it is not really necessary for functionality ;-) Have a great weekend! Peter
TK. Posted November 25, 2012 Posted November 25, 2012 I just look quickly the source, i think it's not so easy. i m suspect that the BPM is just calculate with only 3 digits. yes, therefore we don't have a fourth digit Best Regards, Thorsten.
