John E. Finster Posted November 25, 2012 Posted November 25, 2012 (edited) hi, i have a quick question. i am thinking of a small midibox_64e design and i wanted to know if the meta-event "switch to Bank x" can be used as a shift function, when the button mode "only on" is set. thanks and greets Edited November 25, 2012 by John E. Finster
TK. Posted November 26, 2012 Posted November 26, 2012 Hi, a bank would switch to another setup with different values. The current values won't be stored. Probably the "switch to group" meta event is better for such a purpose, because it switches to a different range within the same bank. Best Regards, Thorsten.
John E. Finster Posted November 26, 2012 Author Posted November 26, 2012 Thanks TK, this info is really helpfull. As far as i understand, only knobs can be assigned to a group, right? But if i connect two buttons to two pins and tell the box, that this is a knob, then sending relative events with that "knob" would leading to two buttons sending two different events. At least something like bome´s midi translator could pick up and translate to two different actions. Combined with the "switch to group x" button in "only on" mode, i could end up with some buttons and the desired shift function for them. Thanks again for the input. Greets
