Rio Posted December 8, 2012 Posted December 8, 2012 (edited) hi, i tried to change a patch of my synthesizer in another bank with the internal mixermap of my SEQ. In general, changing a bank is easy by sending 2 commands #CC00 (MSB) and #CC32 (LSB) (or in simple way: #CC32 only) with a following #PC command. And here i got a problem. The Mixermap allows program change, but not bank selection. So at time i have to do following workaround: i setup the first bar of the mixermap with the 2 assignable CC1 and CC2 to #CC0 and #CC32 and a following second bar with the program change for same parameters (Port, Channel..). That works fine, but - sadly - it would stole me 8 bars of the 16-bar-mixermap (if i want change all at one time) :pinch:. Is there a better way to setup bank selection for a bar in mixermap? Maybe i could code to send CC2 before PrgChg. greets, rio Edited December 8, 2012 by Rio
TK. Posted December 8, 2012 Posted December 8, 2012 No, unfortunately there is no better way. Best Regards, Thorsten.
