SEQV3 mixermap: how to set a bankselect/program change
Rio
hi,
i tried to change a patch of my synthesizer in another bank with the internal mixermap of my SEQ.
In general, changing a bank is easy by sending 2 commands #CC00 (MSB) and #CC32 (LSB) (or in simple way: #CC32 only) with a following #PC command. And here i got a problem.
The Mixermap allows program change, but not bank selection.
So at time i have to do following workaround: i setup the first bar of the mixermap with the 2 assignable CC1 and CC2 to #CC0 and #CC32 and a following second bar with the program change for same parameters (Port, Channel..). That works fine, but - sadly - it would stole me 8 bars of the 16-bar-mixermap (if i want change all at one time) :pinch:.
Is there a better way to setup bank selection for a bar in mixermap? Maybe i could code to send CC2 before PrgChg.
greets, rio
Edited by Rio
