Hello!
A little information would be needed on the uCapps not is not entirely clear how and which software which links to be done in order to midibox64seq v2 can do it!! Someone feltehetné information, drawings, hex! 18F452 has to do with that at home. Thanks in advance! Luis
MIDIbox SEQ V2 is a pretty old software, it won't be supported anymore.
Why are you not upgrading to at least V3 (which is better documented)?
Anyhow, MBSEQ V2 is good for any MIDI device - but the possibilities are very restricted compared to V3 (or V4 of course)
Thanks for your response!
There are all the parts at home, I'd just like to know how it works. The v3 core to the panel is not good, to my knowledge. So if db50xg sound module can interface with V2?
Thank you, Louis.
I set the control panel for it! I hope it will be good instead of the rotary push-button design is good I think it is??
Hello Louis!
post-11253-0-77827200-1368991497_thumb.j
Posted (edited)
Yes a midibox seq v4 will work with a db50xg. In any case the seq v4.075 with an lpc17 core. I built a db50xg into a midio128 controller. Software in the programming forum.
Edited by EsotericLabs
