lajos Posted May 17, 2013 Posted May 17, 2013 Hello! A little information would be needed on the uCapps not is not entirely clear how and which software which links to be done in order to midibox64seq v2 can do it!! Someone feltehetné information, drawings, hex! 18F452 has to do with that at home. Thanks in advance! Luis
lajos Posted May 17, 2013 Author Posted May 17, 2013 (edited) It is suitable for display???CTC LCD Display C240L02YBN00 2X40LINE x Char 1 STÜCK | eBay Edited May 17, 2013 by lajos
lajos Posted May 18, 2013 Author Posted May 18, 2013 Hello! I have a yamaha module db50xg it would be good to midiboxseqV2?? thank you
TK. Posted May 18, 2013 Posted May 18, 2013 Hi, MIDIbox SEQ V2 is a pretty old software, it won't be supported anymore. Why are you not upgrading to at least V3 (which is better documented)? Anyhow, MBSEQ V2 is good for any MIDI device - but the possibilities are very restricted compared to V3 (or V4 of course) Best Regards, Thorsten.
lajos Posted May 19, 2013 Author Posted May 19, 2013 Thanks for your response! There are all the parts at home, I'd just like to know how it works. The v3 core to the panel is not good, to my knowledge. So if db50xg sound module can interface with V2? Thank you, Louis.
lajos Posted May 19, 2013 Author Posted May 19, 2013 I'm sorry now I see that seq V3 18F4620 core panel works! Instead of a five-18F4685 18F4620 Leht use? I do this at home. If yes then to collect the information. Thank you. It is suitable for display! If so you're likely to order! CTC LCD Display C240L02YBN00 2X40LINE x Char 1 STÜCK | eBay
lajos Posted May 19, 2013 Author Posted May 19, 2013 The panels are now finished! Start with the implant! I think they should add!Egy kép!
lajos Posted May 19, 2013 Author Posted May 19, 2013 I set the control panel for it! I hope it will be good instead of the rotary push-button design is good I think it is?? Hello Louis!
EsotericLabs Posted May 25, 2013 Posted May 25, 2013 (edited) Yes a midibox seq v4 will work with a db50xg. In any case the seq v4.075 with an lpc17 core. I built a db50xg into a midio128 controller. Software in the programming forum. Edited May 25, 2013 by EsotericLabs
