Hi MidiBoxers!
Is it difficult to edit the MIDIbox SEQ V4 firmware,
to add custom button shortcuts?
Would this be possible for a MIOS32 programming beginner?
Best regards
Marxon
Hola,
imho it has a great & well-documented code base, better than many "commercial" pieces of software i´ve seen - it should be possible to add what you want, if you have some C knowledge and are willing to read a bit into the code.
Many greets,
Peter
OK thanks!
Seems like i have to edit seq_ui.c because
i want Menu + Rwd to work as a Copy button shortcut.
My first try:
static s32 SEQ_UI_Button_Rew(s32 depressed)
seq_ui_button_state.REW = depressed ? 0 : 1;
if( depressed ) return -1; // ignore when button depressed
if( seq_ui_button_state.MENU_PRESSED ) ///line added
return SEQ_UI_Button_Copy(depressed); ///line added
if( SEQ_SONG_ActiveGet() ) {
portENTER_CRITICAL();
SEQ_SONG_Rew();
portEXIT_CRITICAL();
} else {
//SEQ_UI_Msg(SEQ_UI_MSG_USER, 1000, "We are not", "in Song Mode!");
SEQ_UI_Button_StepViewDec(depressed);
return 0; // no error
But i guess it is not that easy...
Hi again,
...maybe this is already enough for what you want to achieve?
Unfortunately i can not achieve it only by using the configs...
I played with the firmware code some hours.
It was worth the try but it seems without some C knowledge, i will not get it work.
Now i have two options:
Start to lear C or add some additional buttons....
solving a problem with your brain is most often better than solving it with your hands :-D
Ja ja, hast ja Recht :b
Außerdem wäre etwas C Wissen sicherlich auch für andere Sachen nützlich.
Aber der Zeitaufwand... *seufz*
Kannst du eine gute Seite/Ebook empfehlen und mir sagen auf welche "C-Bereiche" ich besonders Wert legen sollte oder ich für MIOS auslassen kann?
mfg
Marxon
Kann Dir leider nicht mit guten Tutorials helfen, ist bei mir schon über 20 Jahre her :-D.
Hier gibt es einige Artikel - alles in allem ein Haufen Arbeit, die aber belohnt wird:
http://www.mikrocontroller.net/articles/C
brief in english: difficult question, can´t help you a lot with that, as it has been too long since I started learning it - linked a few german papers.
Ciao,
Peter
Edited by Hawkeye
Thank both of you for this links!
@EsotericLabs:
Thats something i was looking for.
In the Preface it is written:
"The book is not an introductory programming manual; it assumes some familiarity with basic
programming concepts like variables, assignment statements, loops, and functions."
@Hawkeye:
Your link is good too.
Nice tutorials and downloads.
Thus, the next few weeks are scheduled.
But i am sure you will read from me ;)
Best regards
Marxon
