dOperator Posted July 14, 2013 Posted July 14, 2013 Hi, I'm building a midibox ng atm, with parts of a midibox seq4. Since i didn't leave a gap in the middle of the frontplate like on the seq4, the lcds don't align properly to the knob rows. Now, if i could rotate the right lcd by 180°(like in the picture), it would align a lot better, could maybe even file off the backlit connectors to get the two lcds closer together. Is there a way to rotate the output? Maybe in hardware, like swapping cables or so? I looked into the firmware code, didn't see any options to rotate the output there, i guess it would be possible to code it somehow tho? Not too experienced with electronics nor low-level coding, so help appreciated a lot :smile: Thanks! current state of affairs:
Hawkeye Posted July 14, 2013 Posted July 14, 2013 Sorry, won´t work, as the font/character set is fixed and only a few special characters can be redefined.
dOperator Posted July 14, 2013 Author Posted July 14, 2013 Damnit, aright, have to live with the unaligned lcds then until (if) i make a proper metal frontplate. Thanks for the fast answer!
Nasrudin Posted July 15, 2013 Posted July 15, 2013 maybe you could cut away the the part of the LCD-PCB that stands beside the Display and solder the the wires to the traces manually. it would be a difficult task, but can be sucessfull if the needed traces are available on the backside of the remaining PCB.
