Antix Posted November 24, 2014 Posted November 24, 2014 Patience....my second name Thorsten are there some schematic to see how velocity will work . DACs will drive VCAs ? Best regards Antonio
TK. Posted November 30, 2014 Posted November 30, 2014 It's a simple DOUT based DAC, the ASCII based schematic can be found in the setup_* files (e.g. http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_808%2Fsetup_seq_dr_default.asm ) ;; CV values can also be output via DOUT shift registers ;; This option is sufficient to control the "velocity" of drum instruments, and it's cheap as well! ;; We expect following connections: ;; ;; DOUT 160k ;; D7 ---o---/\/\/\---* ;; 80.6k | ;; D6 ---o---/\/\/\---* ;; 40.2k | ;; D5 ---o---/\/\/\---* ;; 20.0k | ;; D4 ---o---/\/\/\---* ;; 10.0k | ;; D3 ---o---/\/\/\---* ;; 5.1k | ;; D2 ---o---/\/\/\---*----o CV Out ;; 220 Ohm ;; D1 ---o---/\/\/\--------o free assignable trigger ;; 220 Ohm ;; D0 ---o---/\/\/\--------o another free assignable trigger ;; ;; The DOUTx channels are matching with the AOUT channels as specified in the DEFAULT_TRKINFO table above. ;; Allowed values: 1-16 (selects DOUT shift register) or 0 to disable ;; Ensure that DEFAULT_NUMBER_SR is high enough so that all DOUTs are updated. #define DEFAULT_CV_DOUT_SR1 4 #define DEFAULT_CV_DOUT_SR2 5 #define DEFAULT_CV_DOUT_SR3 6 #define DEFAULT_CV_DOUT_SR4 7 #define DEFAULT_CV_DOUT_SR5 8 #define DEFAULT_CV_DOUT_SR6 9 #define DEFAULT_CV_DOUT_SR7 10 #define DEFAULT_CV_DOUT_SR8 11 #define DEFAULT_CV_DOUT_SR9 12 #define DEFAULT_CV_DOUT_SR10 13 #define DEFAULT_CV_DOUT_SR11 14 #define DEFAULT_CV_DOUT_SR12 15 #define DEFAULT_CV_DOUT_SR13 16 #define DEFAULT_CV_DOUT_SR14 0 #define DEFAULT_CV_DOUT_SR15 0 #define DEFAULT_CV_DOUT_SR16 0 Best Regards, Thorsten.
Navicat Posted February 4, 2015 Posted February 4, 2015 (edited) Thanks Throsten for this! Dout to CV! A question for this.. The output voltage is between 0v and +5V right?? If yes is there a way to make this work between 0v and +15? Or far away better for TR-808: Accent = Trigger pulse between +5v and +15v My target is to make a Dout Trigger pulse of 1ms width between +5v and +15v ( This will be the accent for 808 voices ) Update: I know i need a shift register that will be operateable at 15 volts.. I found that http://www.ti.com/product/cd4094b can operate at those voltages but this is not a 3-state output register.. Is this a problem? Regards, Tilemachos Edited February 4, 2015 by Navicat
