lukas412 Posted December 31, 2013 Report Share Posted December 31, 2013 So lately my sequencer has been crashing very intermittently and I can not reliably reproduce it. Every once in a while Ill be editing the port on a track and I will hit OSC4 and the machine will freeze, and nothing will fix it except a reboot. No error message. I can not make this happen when I try to reproduce. I have no ethernet cable hooked up. Also I am not positive that it is just OSC4 that causes or just a coincidence. I have no idea if its hardware or not. Any ideas where I can start? Thanks, Luke Quote Link to comment Share on other sites More sharing options...
TK. Posted January 1, 2014 Report Share Posted January 1, 2014 Could you please give me your complete network configuration? (enter "network" in MIOS Terminal, and copy&paste the output into this thread) It doesn't matter if an ethernet cable is connected or not, I mainly need to know how which OSC protocol is selected for the different ports. Maybe this helps me to reproduce the issue with some stress tests Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
lukas412 Posted January 1, 2014 Author Report Share Posted January 1, 2014 Thanks TK, output below: [92520.937] Loading session Maschine [92520.938] [uIP_TASK] IP address: 192.168.1.180 [92520.938] [uIP_TASK] Netmask: 255.255.255.0 [92520.940] [uIP_TASK] Default Router (Gateway): 192.168.1.1 [92545.267] network [92545.262] Ethernet cable connected: no [92545.263] Ethernet MAC address: 00:5F:00:00:00:D4 [92545.263] Ethernet services running: yes [92545.264] DHCP: disabled [92545.264] IP address: 192.168.1.180 [92545.265] Netmask: 255.255.255.0 [92545.265] Default Router (Gateway): 192.168.1.1 [92545.266] OSC1 Remote address: 192.168.1.101 [92545.267] OSC1 Remote port: 8001 [92545.267] OSC1 Local port: 8000 [92545.268] OSC1 Transfer Mode: 0 - MIDI Messages [92545.268] OSC2 Remote address: 192.168.1.101 [92545.269] OSC2 Remote port: 8001 [92545.269] OSC2 Local port: 8000 [92545.270] OSC2 Transfer Mode: 0 - MIDI Messages [92545.271] OSC3 Remote address: 192.168.1.101 [92545.271] OSC3 Remote port: 8000 [92545.272] OSC3 Local port: 8000 [92545.272] OSC3 Transfer Mode: 1 - Text Msg (Integer) [92545.273] OSC4 Remote address: 192.168.1.101 [92545.273] OSC4 Remote port: 8001 [92545.274] OSC4 Local port: 8000 [92545.275] OSC4 Transfer Mode: 0 - MIDI Messages [92545.275] UDP Monitor: verbose level #0 Quote Link to comment Share on other sites More sharing options...
TK. Posted January 2, 2014 Report Share Posted January 2, 2014 The deselected DHCP is unusual (but of course allowed - seems to be the parameter which causes the problem). Could you please check if the crash can still be reproduced with DHCP enabled? Then I would know where to start searching. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
lukas412 Posted January 2, 2014 Author Report Share Posted January 2, 2014 Absolutely. Ill turn it on and let you know if I see the issue again. thanks, Luke Quote Link to comment Share on other sites More sharing options...
lukas412 Posted January 4, 2014 Author Report Share Posted January 4, 2014 So when I try to turn DHCP on i get this notification: "MBHP_ETH not connected" I am running an LPC17 core and have it fully populated. I have the jumper wires connected and when it boots I see one red flash. Seem like a hardware issue? Thanks, Luke Quote Link to comment Share on other sites More sharing options...
TK. Posted January 4, 2014 Report Share Posted January 4, 2014 Everything ok! I've to change the message - the LPC17 doesn't use the MBHP_ETH module. And "not connected" means for LPC17, that no ethernet cable is connected. Keep it unconnected for this check. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
lukas412 Posted January 4, 2014 Author Report Share Posted January 4, 2014 Issue is it will not let me turn DHCP on. it just flashes the notification and it stays off. LUke Quote Link to comment Share on other sites More sharing options...
TK. Posted January 4, 2014 Report Share Posted January 4, 2014 Ok, I see... Please enable it from the MIOS Terminal: set dhcp on store Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
lukas412 Posted January 4, 2014 Author Report Share Posted January 4, 2014 Excellent that made the setting take. Ill let you know how it works out. Thanks! Luke Quote Link to comment Share on other sites More sharing options...
