LPC17 MIDI out trouble
southpole
hi all,
this is my first post so first i would like to say hello,
and then immediately ask for help :-)
the problem is, MIDI OUT is not working on my CORE_LPC17.
i've built the CORE_LPC17 module and got USB and MIDI IN working,
i.e. i was able to install the bootloader via USB, and then the MIDIBOX_NG
application. commands in the MIOS Studio terminal work fine.
i tested the loopback as described on the MIDI troubleshooting page, and
it works if i take out the LPC17 and short RX and TX via a jumper directly
at the LPC socket (i installed female headers).
so it looks as if there is no problem with the circuitry between the MIDI socket
and the female headers...
MIDI in works correctly with the LPC installed, if i send MIDI commands to MIDI IN
i can see them via USB on the terminal in the midi monitor.
but MIDI out does not work, there is no data transmitted.
i put a LED against the MIDI out socket, and it flickers only briefly directly
after power-up (i think no data is transmitted at that point)
if i measure the voltage directly on the TX pin on the LPC board, it seems to
be constantly at 5V...
any ideas how i can proceed further?
thanks!
Link to comment
Share on other sites
welcome on board! :smile:
This surprises me, because I would expect 3.3V here
Are you sure that it's 5V? Then it very likely related to an unintended bridge on the board, e.g. caused by a big soldering blob between the Tx track and a 5V track.
Link to comment
hi thorsten,
sorry, i measured again more carefully this morning, and counted the pins more carefully.
so, with the USB plugged in i measure 5V on P2.1/RXD1 and 0V on P2.0/TXD1
(also i checked P0.1/RXD3 and P0.0/TXD3 and get also 5V and 0V respectively).
the voltage directly at the MIDI socket is 3.3 V at J12 and J20
(between middle/GND and square via / middle left pin of socket in rear view).
this confuses me a little since according to the schematic i would expect 3.3V on the right side (M+).
these voltages are the same with and without the ICs (IC1,IC2,IC4,IC5, LPC17) or jumpers (apart from J17) in their sockets.
to me the soldering looks clean, all blobs look concave, shiny and covering just the pad ...
and i also thoroughly cleaned the board with alcohol
(if it is possible to attach images here i could attach a picture of it?)
do you have further ideas of points where i could measure to find a short if there is one?
thanks,
Gerhard
Link to comment
RXD = 5V: confirmed
TXD = 0V: very strange, it should be ca. 3.3V when no MIDI data is sent
It's especially strange that you measure 0V at both TXD pins (the same soldering error twice - very unlikely?)
yes, just click on the "My Media" button (right after the smilie)
Could you please check the voltage at the remaining two TX pins?
MIDI OUT3: J5B.A7 (LPC1769 pin P0.2)
MIDI OUT4: J4B.SD (LPC1769 pin P0.11)
And: are you sure that the application is running?
E.g. is the query in MIOS Studio working? Does it return "MIDIbox NG V1.xxx"?
Link to comment
hi thorsten,
the voltages i mentioned above were measured without and IC or the LPC inserted.
when i insert everything an run normally, i get 3.3V at all four TX pins - as expected.
i am 100% sure the LPC17 runs MIDIBOX_NG correctly, i can communicate via terminal
and also have an LCD attached. when i switch on the MIDI monitor i can see MIDI sent
to MIDI_IN1 via USB on the terminal.
Only MIDI_OUT is not working...
for good measure i reflowed now almost all solder points (that were connected to something),
images are attached.
thanks!
gerhard
Link to comment
Hi Gerhard,
how do you test the MIDI OUT, resp. how are you generating the MIDI messages?
By default (if no control element is connected), no data will be sent to the MIDI OUT ports.
You could enable message forwarding from USB with following terminal command:
set router 1 USB1 all OUT1 all
Then play some keys on the virtual keyboard of MIOS Studio -> MIDI OUT1 should output MIDI note messages.
Link to comment
Hi Thorsten,
I'm a little confused now that you say by default no data are sent to MIDI OUT?
It was my understanding that it should be possible by default to communicate with the CORE_LPC17
via the MIDI ports only, and use USB only for power? it is written everywhere in the instructions
that MIDI can be used to upload MIOS32 etc... so i thought for this data have to go through MIDI IN and OUT
by default already when the bootloader runs?
I did your routing suggestion and indeed a few occassional bytes are being sent to MIDI OUT now, so a little bit
of progress :-)
but the data are not the notes sent from the virtual midi keyboard, only very few bytes arrive, mostly FF and FC,
not complete and correct MIDI messages.
i see two possibilities now, either it looks like the path to the MIDI port might be buggy but then it is strange why
the loopback test (shorting RX and TX) worked just fine.
second, the LPC does not send MIDI OUT messages correctly (due to hardware issue on the LPC board,
or due to a MIOS software issue that has for some reason not been seen yet...)
can i somehow read the MIDI messages directly at the TX pins?
thanks,
gerhard
Link to comment
Hi Gerhard,
the reason why I came to the idea that you are testing the MIDI OUT wrongly was simply because you haven't described how exactly you are testing the MIDI OUT port.
It was the only conclusion at my side.
Especially since you wrote "but MIDI out does not work, there is no data transmitted."
I'm pretty sure that this is not related to a software issue, maybe only due to a configuration problem (like if you would assume, that USB transfers would be forwarded to a MIDI port w/o special app configuration)
Ok, next experiment (unfortunately again you haven't described *all* details, e.g. which MIDI interface you are using to test the OUT port, therefore I hope that following test won't confuse you again - just trust my guidance... ;-)
What happens if you loopback MIDI OUT1 to MIDI IN1, and configure the MIDI router the following way:
set router 1 USB1 ALL OUT1 ALL
set router 2 IN1 ALL USB1 ALL
I expect, that every MIDI note that you are sending with the virtual keyboard will now be sent back by the core due to the MIDI loopback.
Accordingly, the MIDI IN Monitor of MIOS Studio should show the same events like the MIDI OUT monitor.
Link to comment
hi thorsten,
Ok, i will do this routing test a bit later, but i can immediately explain my setup to you in more detail,
sorry for assuming this was unambiguous, you are of course right it is not ...
I have a laptop (Apple MBPr with Mavericks) with a USB cable in one USB port going to the USB port in the CORE_LPC17,
and a USB-MIDI cable (Roland UM-1) in the other USB port going to the CORE_LPC17 MIDI_IN1 and MIDI_OUT1 sockets.
all ports (MIOS32, and UM-ONE, respectively) are correctly recognized by MIOS studio and other MIDI monitor applications
running on the computer.
when i set the in/out ports in MIOS Studio to "MIOS32" (the MIDI port assigned to the USB cable),
the LPC17 is correctly recognized and communication is possible.
when i send MIDI data from another virutal keyboard to the UM-ONE, i can see it in the LPC17 terminal on IN1.
when i set the in/out ports in MIOS Studio to "UM-ONE" (the MIDI ports assigned to the Roland UM-1 interface) no communication is possible anymore.
this is how i conclude only the MIDI OUT is not working.
for the previous (hardware) loopback test i removed the CORE_LPC17 and shorted the pins in the empty female headers.
this worked.
i'll write again once i did your suggested routing loopback test.
thanks,
Gerhard
Link to comment
Hi Thorsten,
Further test results:
- Your proposed loopback test works (routing USB1 --> OUT1 --> cable --> IN1 --> USB1) : more progress :-)
- I also tried to just route USB1 --> OUT1 (leaving IN1-->USB1 open) with the same loopback cable to IN1
  and can see the events come back via IN1 in the midimon in the terminal
- These tests I repeated with permuting the cables between IN1/2, OUT1/2 and got the expected results in each case
--> the LPC17 seems to be able to talk to itself just fine
- I repeated the "jumper" loopback test (taking out the LPC17 and shorting Rx/Tx  on both with two different MIDI interfaces
  (the Roland cable and a no-name cable), it also works flawlessly
--> the Mac seems to be able to talk to itself just fine, and going through the octocouplers etc also seems to work
now, what does not work is any test that sends MIDI data via IN1/2,OUT1/2 between the Mac and the LPC17.
some data do get transmitted, but they are wrong and incomplete, bytes get lost. i see that in the MIOS midi monitor
and on third-party midi monitors.
from these tests i conclude there might be a problem in synchronizing the
communication between the Mac and the LPC17,
perhaps the MIDI baud rate is not set correctly, or something like that... ?
thanks,
Gerhard
Link to comment
It can't be changed by the user without recompiling the application, therefore very unlikely.
And LPC17 wouldn't be able to receive MIDI messages from your Roland UM1 if the baudrate would be wrong.
I think that it it's neither a synchronization, nor any other software issue.
It seems, that your Roland UM1 interface can't handle MIDI signals at 3.3V level correctly.
There is a small number of MIDI devices where this is the case, they are designed for 5V signals, but LPC1769 (like many other modern microcontrollers) can only supply 3.3V.
Therefore the next test: try another MIDI device.
If it works, then we can start to think about workarounds for your Roland UM1 (e.g. usage of a level shifter).
Link to comment
Hi Thorsten,
I tried with another MIDI Interface (Prodipe 1in/1out) which exhibits the same problematic behaviour.
Also, I tested MIDI loopback with another device (Mutable Instruments MIDIpal) which also
includes a MIDI monitor and MIDI thru feature and it works just fine with both interfaces, the Roland
and the Prodipe.
(Not sure if the MIDIpal uses a 5V signal on the output though...)
Another thing i googled is that apparently many MIDI interfaces still have problems with MacOSX Mavericks
since it is quite new.
however, since i tried with two different MIDI interfaces, and I have no problems with the MIDIpal (or any
of my other synthesizer I connected previously) I doubt it is a driver issue.
I am therefore ready to try your level shifting idea :-)
Thanks,
Gerhard
Link to comment
Hi!
I was having the exact trouble Gerhard describes.
USB is/was working perfectly. But when powered from a wall-wart with a MIO iConnect the MIOS Application is not recognized, MIDI In works fine, but MIDI Out does not work at all.
When I switched interfaces to my Scarlett 2i4 everything works perfectly.
The thing that threw me off track is that the MIO iConnect plays perfectly with my sammichFM (among others), so I didn't stop to consider that the interface was the issue- I assumed my soldering skills were at fault. Apparently it is one of these interfaces that does not recognize 3.3v, only 5v that TK describes.
I'll update the white and blacklist with my findings.
Best of luck Gerhard!!
-dugan
Link to comment
Before trying to level shift the Tx signal (which involves some soldering work and an additional IC, such as a 74HCT541), following experiments would be interesting.
1) connect your MIDI synthesizer to MIDI OUT1 - are you able to play notes?
2) connect your MIDI Pal between MIDI IN1 and OUT1 - does it show the outgoing MIDI data, and is MIDI loopback working?
3) and now the trick: bridge R21 (a 220 ohm resistor) with a small cable so that it doesn't limit the current draw anymore.
Together with R22 (the second 220 ohm resistor which shouldn't be bridged (!) to prevent a short circuit between ground and 3.3V while plugging in the cable), this should result into a current draw of ca. 7.5 mA, which is still close to the MIDI spec, but might help in your case.
Background: actually the MIDI spec says, that the current loop requires about 5 mA. Assumed that the MIDI Out has two 220 Ohm resistors in serial, and the MIDI IN of the target device has a single 220 Ohm resistor as well, this results into exactly 3.3V / 3*220 Ohm = 5 mA
However, some interfaces might have a poorly designed MIDI IN circuit, so that this is not enough to drive the optocoupler.
@Dugan: could you please also check if 3) solves the issue at your side?
If this solves the issue, I will document the workaround at the MBHP_CORE_LPC17 page.
Fortunately with the STM32F4 core it will be possible to use the Tx pin in Open Drain mode again, so that MIDI OUT can be supplied at 5V and therefore no adaption issues can be expected (due to a hardware imperfection in the LPC1769 chip this isn't possible).
Link to comment
I was just about to suggest this to.  Running the Midi OUT with only 3.3v you would suspect that these 220 ohm resistors would need to be changed. I've questioned this for a year or more but nobody was reporting any issues.
Edit: TK - on your calculations you forgot to subtract the forward voltage of the receiving diode which is 1.7v max at only 1.6ma.  So the voltage is really 1.6 volts, not 3.3v.
Edited by kpete
Link to comment
Hi Thorsten,
First i would like to report that also for me the LPC17 communicates normally if i bridge R21 :-)
Thanks for all the help!
I guess I have to also bridge R26 to get OUT2 working?
Second, i did the tests you requested (before bridgeing):
1) Connecting a synthesizer (Korg EM-1, not really a synth but a fairly standard toy...) works,
    in both directions
2) loopback through MIDIpal works even with R1 in - looking at the MIDIpal PCB it has written 3.3V all over it,
    so i'm guessing its also 3.3V. i can see two 220 Ohm resistors close to the 6N138. not sure about the acutal
    schematics because Olivier has taken them down i think, but probably MIDIpal is prepared for 3.3V operation
    so that could explain the success.
so, it looks as if only the connection between the Roland and Prodipe USB-MIDI interfaces did not work.
last test i did before soldering in the bridges is to test the Roland in "iPad mode" (a small switch on the cable) ...
i thought this maybe switches the device to lower currents/voltage, but it didn't work
Thanks again, I'm happy to finally have learned more about MIDI :-)
Gerhard
Link to comment
I'm glad you got yours working, too Gerhard!
It's a testament to TK's incredible knowledge that he solved this issue with conjecture alone.
You and I should update the wiki's blacklist and/or whitelist with our interfaces so the next cats who come upon this are less blind than we were. -I think TK is going to update the LPC17 page to indicate that some USB/Midi interfaces will behave better with the workaround he provided.
Just to confirm against better minds than my own: Removing the 220 Ohm resistor only adds ca. 2.5mA to the Midi Out signal path and should not be deleterious to most/any equipment connected to it, correct?
Thanks!!
dugan
EDIT: Gerhard- The kludge is only so that your Midi/PC interface works with your PC & MIOS Studio... You only need to bridge R26 if (for some weird reason) your Midi Out isn't working with your other Midi hardware... in my case Midi Out always worked with my midi hardware, just not with MIOS Studio. ...If it is confirmed (by folks smarterer than me) that there is nothing deleterious about removing R26 (&r21) you can if you like, but I see no reason to do so if it's communicating with the equipment that you want it to. You already have MidiOut 1 & USB to talk to MIOS Studio, there's no reason to have 3 ways of getting Midi Out messages to MIOS Studio... I think...
TK (or another genius): The R21 / R26 resistors are only there to rectify the signal to ~5mA if the initial voltage was 5v, right?
Cheers!
Edited by consumer
  • Like 1
Link to comment
Hi Dugan,
good point. it's true that all devices i tested with the second port worked apart from the PC so i'll leave R26 in for now.
perhaps a flexible solution would be to include a jumper on future revisions of the CORE_LPC17 board
in order to short R21/R26 if neccessary for the particular users setup.
Cheers,
Gerhard
Link to comment
My guess what TK proposed is not going to be the final fix.  It was just to see if it solved the problem.
The three 220 ohm resistors in the transmit and receive sides are put in circuit so that plugging the wrong equipment into any of the Midi ports wouldn't destroy equipment at either end.
The Midi spec indicates a 5ma current loop.  This current is achieved by the 3-220 ohm resistors in the loop and the +5v supply voltage with an assumed voltage drop of 1.7v across the receiving opto-isolator.  With a 5 volt source you get 5v-1.7v/3-220 ohms = 5ma.  With  only a 3.3v source from the LPC unit, this current is reduced to 3.3v-1.7v/3-220 ohms = 2.42ma which is less than half that it should work with.
I believe that the 2 resistors on the Midi Out port should not be bypassed, but changed to a value of 47 ohms.  This would give 3.3-1.7/(47+47+220) = 5.09ma.  My opinion is that these 47 ohm resistors are a little lower than what I would want for protection but they still provide some protection and still gives enough current to meet the spec.  We will wait and see what TK's final approach will be.
Pete
Link to comment
Congratulations Pete, this time you replied 1 minute earlier than me! (because I compared some schematics in the internet... ;-)
And I agree with you, that 47 Ohm is the best choice!
(we would also have to consider the internal resistance of the TX pad, and of the MIDI cable...)
However, I'm glad that we got this solved!  :smile:
The purpose of these resistors is to limit the current, especially if somebody plugs MIDI OUT into another MIDI OUT or THRU, or if the MIDI cable is broken (in worst case, the 5V resp. 3.3V supply voltage would be connected to ground), or if the cable has the wrong polarity.
I remember that ca. 20..30 years ago (the time MIDI came up) some kind of crosslink cables with the same plugs were sometimes used for hifi systems, e.g. for tape-to-tape recording. If you would connect such a cable between two MIDI devices, you would drive the optocoupler at the other side in the wrong direction, and without current limiting it would heat it up.
At the optocoupler site there is a polarity protection as well (the 1N4148 diode) - but if it doesn't exist in the MIDI device with a poorly designed MIDI IN circuit, there is a certain danger that the optocoupler will be fried.
This is very hypothetical, but it's always a good idea to consider such safety measures at both sides! ;-)
Meanwhile I also changed the MBHP_CORE_LPC17 schematic and the BOM: I'm now recommending 47 Ohm resistors for R21, R22, R26 and R27 - the reason for this measure is described in the list of LPC17 imperfections.
I recommend you to do the same.
E.g. I just checked how Mutable Instruments implemented the MIDI OUT. They are using a 100 Ohm resistor at the 3.3V pin, but no resistor at the Tx pin. For the Shruthi synth they are using a 220 Ohm resistor at the 5V pin, and again no resistor at the Tx pin.
Hypothesis: if somebody would plug the MIDI OUT of a MIDI Pal into the MIDI OUT of a Shruthi (by fault), it would result into a short circuit between 5V and 3.3V, which is only limited by the internal resistors and protection diodes of the Tx pins. This isn't really so dangerous, but it's also not so nice...
Such an issue is btw. another good reason, why it's better to configure the Tx pin in open drain mode instead of push-pull if the MCU allows this.
Link to comment
Guest
Reply to this topic...
