Posted (edited)
Hello
I was reading the manual but couldnt find anything regarding a Midi Thru option (so that the sammichFM forwards the Midi Input to the Out).
I saw there is a midi merger option, which it seems, i am not able to select with my 2x20 char display in CFG Mode (i can not scroll in the CFG Page).
Any ideas?
Thanks
Patrick
Edited by RyuX
I seem to recall there was a way to do Thru on the FM, though I haven't yet had the need to use it. I think you may have to make a modification to MIDI Out for it to work though? It's been a long while so I don't remember readily.
One option you have is to build something that includes a MIDI router (e.g. MBSEQ, MIDIO128, MBNG) and have it handle your MIDI interfaces and routing. Not quite what you're after, but might be something to consider if you can't get Thru working on MBFM directly.
