portervance Posted July 17, 2014 Report Share Posted July 17, 2014 I've been scratching my eyes out trying to figure why I can't load the MIOS bootloader onto my LPC board. I've tried using the LPC IDE on some of my other machines but had no luck getting them to communicate with the LPC board via USB. I plugged the LPC into my Windows 7 laptop today and I finally got the Program Flash window to pop up successfully. Now when I try to flash the LPC I am getting an error in the IDE software, "Target is not marked as debuggable". I've read a few posts here that suggest trying different USB cables and I've tried 3 different ones so far with no luck. I've also tried playing around with some of the debugging options in the IDE, setting debugging to "none" in the Perspectives panel, also toggling Vector caching to True as NXP's documents suggest, but neither has fixed the issue. The only other option I have to try is installing a newer version of the IDE software (I'm running an older version, 5 I believe) but I'm really upset at this error message! Any suggestions on how to fix this so I can flash MIOS onto my LPC board would be appreciated. Thank you! Quote Link to comment Share on other sites More sharing options...
TK. Posted July 17, 2014 Report Share Posted July 17, 2014 Which version of the IDE are you using? At the MBHP_CORE_LPC17 project page v5.2.6 is recommended: http://www.lpcware.com/lpcxpresso/downloads/older Because newer versions are not working (according to some posts in this forum) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
portervance Posted July 17, 2014 Author Report Share Posted July 17, 2014 Yes, 5.2.6 is the IDE I've been using since I tried using the newer versions and the FreeRTOS projects were not in the templates. Any ideas? Quote Link to comment Share on other sites More sharing options...
TK. Posted July 17, 2014 Report Share Posted July 17, 2014 Are you trying to program the unmodified LPCXPRESSO module standalone, or did you already mount it on the MBHP_CORE_LPC17 module? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
portervance Posted July 17, 2014 Author Report Share Posted July 17, 2014 Yup, LPCXPRESSO board still has the programmer connected to it and I don't have it plugged into anything else at the moment. Just standalone. Quote Link to comment Share on other sites More sharing options...
portervance Posted July 26, 2014 Author Report Share Posted July 26, 2014 bump Quote Link to comment Share on other sites More sharing options...
TK. Posted July 26, 2014 Report Share Posted July 26, 2014 You are doing everything right. I've no additional idea why it shouldn't be possible to program the target with this IDE version. :-/ You even tried multiple PCs... somehow I've the impression that the LPCXPRESSO module is defective. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
