novski Posted July 26, 2014 Report Share Posted July 26, 2014 Hi Im Trying to get my Matrix working but have some problems with the commands. Getting back to this in my Vacation im now testing the self-made board of this Schematic: Im trying to program it in MIOS but i can't find out why the second and third button row doesn't react. And instead the First row shows all three Values by pressing the corresponding button of the first row. The LEDs don't light up at all... Based on the Testfiles i added some helpful code to display the pressed Value but in main its from repository: RESET_HW LCD "%C" LCD "@(1:1:1)OLED1" LCD "@(2:1:1)OLED2" LCD "@(3:1:1)OLED3" LCD "@(4:1:1)OLED4" LCD "@(5:1:1)OLED5" LCD "@(6:1:1)OLED6" LCD "@(7:1:1)OLED7" LCD "@(8:1:1)OLED8" # In this demo we configure individual brightness levels for the LEDs from EVENT_BUTTON events LCD "@(1:10:1)RGB Demo #2" DIN_MATRIX n=1 rows=8 inverted=1 sr_dout_sel1=1 sr_din1=1 button_emu_id_offset=1001 DOUT_MATRIX n=1 rows=8 inverted=0 sr_dout_sel1=1 sr_dout_r1=2 sr_dout_g1=3 sr_dout_b1=5 led_emu_id_offset=1001 # These button functions forward their value also to LEDs # it's possible to set the rgb levels in the button event, it will be forwarded as well! EVENT_BUTTON id=1001 fwd_id=LED:1001 type=NoteOn key=36 chn=1 rgb=15:0:0 lcd_pos=1:1:2 label="^std_btn" EVENT_BUTTON id=1002 fwd_id=LED:1002 type=NoteOn key=37 chn=1 rgb=15:0:0 lcd_pos=2:1:2 label="^std_btn" EVENT_BUTTON id=1003 fwd_id=LED:1003 type=NoteOn key=38 chn=1 rgb=15:0:0 lcd_pos=3:1:2 label="^std_btn" EVENT_BUTTON id=1004 fwd_id=LED:1004 type=NoteOn key=39 chn=1 rgb=15:0:0 lcd_pos=4:1:2 label="^std_btn" EVENT_BUTTON id=1005 fwd_id=LED:1005 type=NoteOn key=40 chn=1 rgb=15:0:0 lcd_pos=5:1:2 label="^std_btn" EVENT_BUTTON id=1006 fwd_id=LED:1006 type=NoteOn key=41 chn=1 rgb=15:0:0 lcd_pos=6:1:2 label="^std_btn" EVENT_BUTTON id=1007 fwd_id=LED:1007 type=NoteOn key=42 chn=1 rgb=15:0:0 lcd_pos=7:1:2 label="^std_btn" EVENT_BUTTON id=1008 fwd_id=LED:1008 type=NoteOn key=43 chn=1 rgb=15:0:0 lcd_pos=8:1:2 label="^std_btn" EVENT_BUTTON id=1009 fwd_id=LED:1009 type=NoteOn key=52 chn=1 rgb=15:15:0 lcd_pos=1:1:3 label="^std_btn" EVENT_BUTTON id=1010 fwd_id=LED:1010 type=NoteOn key=53 chn=1 rgb=15:15:0 lcd_pos=2:1:3 label="^std_btn" EVENT_BUTTON id=1011 fwd_id=LED:1011 type=NoteOn key=54 chn=1 rgb=15:15:0 lcd_pos=3:1:3 label="^std_btn" EVENT_BUTTON id=1012 fwd_id=LED:1012 type=NoteOn key=55 chn=1 rgb=15:15:0 lcd_pos=4:1:3 label="^std_btn" EVENT_BUTTON id=1013 fwd_id=LED:1013 type=NoteOn key=56 chn=1 rgb=15:15:0 lcd_pos=5:1:3 label="^std_btn" EVENT_BUTTON id=1014 fwd_id=LED:1014 type=NoteOn key=57 chn=1 rgb=15:15:0 lcd_pos=6:1:3 label="^std_btn" EVENT_BUTTON id=1015 fwd_id=LED:1015 type=NoteOn key=58 chn=1 rgb=15:15:0 lcd_pos=7:1:3 label="^std_btn" EVENT_BUTTON id=1016 fwd_id=LED:1016 type=NoteOn key=59 chn=1 rgb=15:15:0 lcd_pos=8:1:3 label="^std_btn" EVENT_BUTTON id=1017 fwd_id=LED:1017 type=NoteOn key=68 chn=1 rgb=15:4:0 lcd_pos=1:1:4 label="^std_btn" EVENT_BUTTON id=1018 fwd_id=LED:1018 type=NoteOn key=69 chn=1 rgb=15:4:0 lcd_pos=2:1:4 label="^std_btn" EVENT_BUTTON id=1019 fwd_id=LED:1019 type=NoteOn key=70 chn=1 rgb=15:4:0 lcd_pos=3:1:4 label="^std_btn" EVENT_BUTTON id=1020 fwd_id=LED:1020 type=NoteOn key=71 chn=1 rgb=15:4:0 lcd_pos=4:1:4 label="^std_btn" EVENT_BUTTON id=1021 fwd_id=LED:1021 type=NoteOn key=72 chn=1 rgb=15:4:0 lcd_pos=5:1:4 label="^std_btn" EVENT_BUTTON id=1022 fwd_id=LED:1022 type=NoteOn key=73 chn=1 rgb=15:4:0 lcd_pos=6:1:4 label="^std_btn" EVENT_BUTTON id=1023 fwd_id=LED:1023 type=NoteOn key=74 chn=1 rgb=15:4:0 lcd_pos=7:1:4 label="^std_btn" EVENT_BUTTON id=1024 fwd_id=LED:1024 type=NoteOn key=75 chn=1 rgb=15:4:0 lcd_pos=8:1:4 label="^std_btn" While the Midimoitor shows this while pressing and depressing button 1 row 0: [13821.564] 90 24 7f Chn# 1 Note On C-1 Vel:127 [13821.567] 90 44 7f Chn# 1 Note On G#3 Vel:127 [13821.578] 90 34 7f Chn# 1 Note On E-2 Vel:127 [13821.760] 90 24 00 Chn# 1 Note Off C-1 (optimized) [13821.763] 90 44 00 Chn# 1 Note Off G#3 (optimized) [13821.774] 90 34 00 Chn# 1 Note Off E-2 (optimized) Can somebody help me with that? Novski Quote Link to comment Share on other sites More sharing options...
TK. Posted July 26, 2014 Report Share Posted July 26, 2014 I had a quick look into the schematic. It looks like you are using 3 rows for the LEDs, and 3 for the buttons, right? In this case I would use row=4 for both matrices (DIN_MATRIX and DOUT_MATRIX), so that the row selection signals will be duplicated (visible at D0..D3 and D4..D7) This doesn't explain why the buttons trigger the events of 3 rows at once, but it might be a good starting point for debugging. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
novski Posted July 26, 2014 Author Report Share Posted July 26, 2014 Hi TK. Yes thats correct i use 3 Rows for LEDs and 3 Rows for Buttons from the same Shift Register. I just tryed to change the rows=8 to rows=4 but that didn't change any of the behaviors. I also noticed that the DIN_Matrix line was inverting=1 what i now changed to inverting=0. Is the schematic done right? Thank you best regards, novski Quote Link to comment Share on other sites More sharing options...
TK. Posted July 27, 2014 Report Share Posted July 27, 2014 The schematic looks correct. Maybe an electrical problem? Are you able to remove the button matrix from the remaining circuit? Then just connect the row selection signals (IC1 Pin 7, 6, 5) with the column inputs at IC2 with a cable, one after another. Each connection should trigger an individual MIDI event. If this doesn't work, connect an alternative DIN and DOUT module (or a MBHP_DIO_MATRIX if available) and check the same. This ensures that the matrix configuration is correct, and that you know where to continue debugging... Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
novski Posted July 27, 2014 Author Report Share Posted July 27, 2014 (edited) Hi TK. Thanks for your reply I can't swap anything because of the rubber buttons i made all in surface mount on the Bottomside of the PCB... To me it looks like the column are short but if i measure B1 to B9 its a open line in both sides. also if i push the button B1 while i measure, B1 and B9 are not short connected... I changed both SR 1&2 but it stays the same. If i press B1 the Value of B1,9,17 goes to Value 127 and all three LEDs lit up. as they should but if they get V127 but i don't know from where they get the V127 because im pressing just B1. no clue. i need a beer. :mad: Edited July 27, 2014 by novski Quote Link to comment Share on other sites More sharing options...
TK. Posted July 27, 2014 Report Share Posted July 27, 2014 Try another hardware module (e.g. MBHP_DIN and DOUT module) after the beer ;) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
novski Posted July 27, 2014 Author Report Share Posted July 27, 2014 (edited) Why does this work RESET_HW LCD "%C" LCD "@(1:1:1)OLED1" LCD "@(2:1:1)OLED2" LCD "@(3:1:1)OLED3" LCD "@(4:1:1)OLED4" LCD "@(5:1:1)OLED5" LCD "@(6:1:1)OLED6" LCD "@(7:1:1)OLED7" LCD "@(8:1:1)OLED8" # In this demo we configure individual brightness levels for the LEDs from EVENT_BUTTON events LCD "@(1:10:1)RGB Demo #2" DIN_MATRIX n=1 rows=4 sr_dout_sel1=1 sr_din1=1 button_emu_id_offset=1001 DOUT_MATRIX n=1 rows=4 sr_dout_r1=2 sr_dout_g1=3 sr_dout_b1=4 led_emu_id_offset=1025 # These button functions forward their value also to LEDs # it's possible to set the rgb levels in the button event, it will be forwarded as well! EVENT_BUTTON id=1001 fwd_id=LED:1025 type=NoteOn key=36 chn=1 rgb=15:0:0 lcd_pos=1:1:2 label="^std_btn" EVENT_BUTTON id=1002 fwd_id=LED:1026 type=NoteOn key=37 chn=1 rgb=15:0:0 lcd_pos=2:1:2 label="^std_btn" EVENT_BUTTON id=1003 fwd_id=LED:1027 type=NoteOn key=38 chn=1 rgb=15:0:0 lcd_pos=3:1:2 label="^std_btn" EVENT_BUTTON id=1004 fwd_id=LED:1028 type=NoteOn key=39 chn=1 rgb=15:0:0 lcd_pos=4:1:2 label="^std_btn" EVENT_BUTTON id=1005 fwd_id=LED:1029 type=NoteOn key=40 chn=1 rgb=15:0:0 lcd_pos=5:1:2 label="^std_btn" EVENT_BUTTON id=1006 fwd_id=LED:1030 type=NoteOn key=41 chn=1 rgb=15:0:0 lcd_pos=6:1:2 label="^std_btn" EVENT_BUTTON id=1007 fwd_id=LED:1031 type=NoteOn key=42 chn=1 rgb=15:0:0 lcd_pos=7:1:2 label="^std_btn" EVENT_BUTTON id=1008 fwd_id=LED:1032 type=NoteOn key=43 chn=1 rgb=15:0:0 lcd_pos=8:1:2 label="^std_btn" EVENT_BUTTON id=1009 fwd_id=LED:1033 type=NoteOn key=52 chn=1 rgb=0:15:0 lcd_pos=1:1:3 label="^std_btn" EVENT_BUTTON id=1010 fwd_id=LED:1034 type=NoteOn key=53 chn=1 rgb=0:15:0 lcd_pos=2:1:3 label="^std_btn" EVENT_BUTTON id=1011 fwd_id=LED:1035 type=NoteOn key=54 chn=1 rgb=0:15:0 lcd_pos=3:1:3 label="^std_btn" EVENT_BUTTON id=1012 fwd_id=LED:1036 type=NoteOn key=55 chn=1 rgb=0:15:0 lcd_pos=4:1:3 label="^std_btn" EVENT_BUTTON id=1013 fwd_id=LED:1037 type=NoteOn key=56 chn=1 rgb=0:15:0 lcd_pos=5:1:3 label="^std_btn" EVENT_BUTTON id=1014 fwd_id=LED:1038 type=NoteOn key=57 chn=1 rgb=0:15:0 lcd_pos=6:1:3 label="^std_btn" EVENT_BUTTON id=1015 fwd_id=LED:1039 type=NoteOn key=58 chn=1 rgb=0:15:0 lcd_pos=7:1:3 label="^std_btn" EVENT_BUTTON id=1016 fwd_id=LED:1040 type=NoteOn key=59 chn=1 rgb=0:15:0 lcd_pos=8:1:3 label="^std_btn" EVENT_BUTTON id=1017 fwd_id=LED:1041 type=NoteOn key=68 chn=1 rgb=0:0:15 lcd_pos=1:1:4 label="^std_btn" EVENT_BUTTON id=1018 fwd_id=LED:1042 type=NoteOn key=69 chn=1 rgb=0:0:15 lcd_pos=2:1:4 label="^std_btn" EVENT_BUTTON id=1019 fwd_id=LED:1043 type=NoteOn key=70 chn=1 rgb=0:0:15 lcd_pos=3:1:4 label="^std_btn" EVENT_BUTTON id=1020 fwd_id=LED:1044 type=NoteOn key=71 chn=1 rgb=0:0:15 lcd_pos=4:1:4 label="^std_btn" EVENT_BUTTON id=1021 fwd_id=LED:1045 type=NoteOn key=72 chn=1 rgb=0:0:15 lcd_pos=5:1:4 label="^std_btn" EVENT_BUTTON id=1022 fwd_id=LED:1046 type=NoteOn key=73 chn=1 rgb=0:0:15 lcd_pos=6:1:4 label="^std_btn" EVENT_BUTTON id=1023 fwd_id=LED:1047 type=NoteOn key=74 chn=1 rgb=0:0:15 lcd_pos=7:1:4 label="^std_btn" EVENT_BUTTON id=1024 fwd_id=LED:1048 type=NoteOn key=75 chn=1 rgb=0:0:15 lcd_pos=8:1:4 label="^std_btn" but as soon as i have this: EVENT_BUTTON id=1024 fwd_id=LED:1048 type=NoteOn key=75 chn=1 rgb=0:0:15 lcd_pos=8:1:4 label="^std_btn" EVENT_LED hw_id=1 At the bottom of my .NGC it sets every Value in the Collum to 127. Now it works. :rofl: Wow. im so glad i found that... It took me an entire day! Edited July 27, 2014 by novski Quote Link to comment Share on other sites More sharing options...
ilmenator Posted July 27, 2014 Report Share Posted July 27, 2014 So what was the problem? Quote Link to comment Share on other sites More sharing options...
novski Posted July 27, 2014 Author Report Share Posted July 27, 2014 The tiny line on the end of my script was evil to me today... EVENT_LED hw_id=1 Made that when pressing a single button in the first row then all LEDs in that column went on. You might think its not possible, but it took me a day to realize that... :sad: Well the wether was not good at all, so didn't miss anything. best regards, novski Quote Link to comment Share on other sites More sharing options...
novski Posted July 28, 2014 Author Report Share Posted July 28, 2014 (edited) Hi Today i tried a new part of my Fadercore, its a Matrix of 8 rows and 16 LEDs. Purposed to be a LED Level-Meter. To test, i connected just one Row and 16LEDs and hocked a Encoder to a DIN board. So by turning the Encoder i get a Value from 0 to 127. Then i wanted to make a simple Test like it wold be LEDs around the Encoder. But somehow again, i don't understand why my code doesn't work. This is my .NGC file: RESET_HW LCD "%C" LCD "@(1:1:1)OLED1" # Test D-OUT LEDmatrix board DOUT_MATRIX n=1 rows=8 mirrored_row=0 inverted_sel=0 sr_dout_row=1 sr_dout_sel1=2 sr_dout_sel2=3 # Matrix control by a Encoder connected to DIN ENC n=1 sr=1 pins=0:1 type=detented2 EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label="^std_enc" LED_MATRIX_PATTERN=1 LED_MATRIX_PATTERN n= 1 pos= 0 pattern=0000000000000000 LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1000000000000000 LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1100000000000000 LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1110000000000000 LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111000000000000 LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111100000000000 LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111110000000000 LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111000000000 LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111100010000 LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000 LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000 LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000 LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000 LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000 LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100 LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110 LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111 I see the Value rising but the LEDs are always ON. Also if i turn "inverted_sel=1" What am i doing wrong? best regards novski Edited July 28, 2014 by novski Quote Link to comment Share on other sites More sharing options...
TK. Posted July 28, 2014 Report Share Posted July 28, 2014 Btw.: the EVENT_LED "trick" isn't understood at my side, it should work properly without. And if now even such a simple DOUT matrix configuration doesn't work at your side (it looks correct), something seems to be totally wrong. Could it be, that you are using an (old) .NGR script which may overwrite certain configurations? You've edited the right file, and always checked that MBNG didn't report any error or warning during the upload & execution? Or you are using a modified firmware build which causes such problems? Which core module are you using btw.? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
novski Posted July 28, 2014 Author Report Share Posted July 28, 2014 im using a LPC1769 since my STM32F4Disco turned out to be the smal brother... :pinch: (its on the way to you now...) I havent changed or Deleted the Files since a long time so the .NGR was never touched and is empty. -> i just had to notice that there is a warning and it reports that there is no LED.NGR file. [117358.626] [MBNG_FILE_C:8] WARNING: unsupported parameter in DOUT_MATRIX n=1 ... sr_dout_row=1 [117358.666] [MBNG_FILE_C] Event Pool Number of Items: 1 [117358.666] [MBNG_FILE_C] Event Pool Allocation: 41 of 24576 bytes (0%) [117358.666] Patch 'LED' loaded from SD Card! [117358.678] [MBNG_FILE_R] /LED.NGR (optional run script) not found Quote Link to comment Share on other sites More sharing options...
TK. Posted July 28, 2014 Report Share Posted July 28, 2014 WARNING: unsupported parameter in DOUT_MATRIX n=1 ... sr_dout_row=1 means: the sr_dout_row parameter doesn't exist. means: there is no shift register assigned to drive the rows. means: it makes sense to read in the documentation which parameter allows you to assign the shift register -> http://www.ucapps.de/midibox_ng_manual_ngc.html means: thereafter there is a higher chance that the LED matrix will work. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
novski Posted July 28, 2014 Author Report Share Posted July 28, 2014 yes. found it. thanks for your patience... for future, this is the correct syntax: RESET_HW LCD â€%C†LCD â€@(1:1:1)OLED1†# Test D-OUT LEDmatrix board DOUT_MATRIX n=1 rows=8 inverted=1 sr_dout_sel1=1 sr_dout_r1=2 sr_dout_r2=3 # Matrix control by a Encoder connected to DIN ENC n=1 sr=1 pins=0:1 type=detented2 EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label=“^std_enc†LED_MATRIX_PATTERN=1 LED_MATRIX_PATTERN n= 1 pos= 0 pattern=0000000000000000 LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1000000000000000 LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1100000000000000 LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1110000000000000 LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111000000000000 LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111100000000000 LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111110000000000 LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111000000000 LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111100000000 LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000 LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000 LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000 LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000 LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000 LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100 LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110 LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111 Quote Link to comment Share on other sites More sharing options...
