Stigmata Posted November 24, 2003 Posted November 24, 2003 Hi there!Just an question..I´m using the sid firm 1.5c.And I can´t get sync of the arpeggiator.I have the rate of the WT to 123 (as Thorsten write before) And the Clk in CFG menu to W_ _.And I´m sendig the MIDI Time code from Cubase SX.Should I go back to the SID 1.5b or...Thank´sChristoffer
TK. Posted November 26, 2003 Posted November 26, 2003 Hi Christoffer,not the MIDI time code, but MIDI clock has to be sent by your application.Best Regards, Thorsten.
Stigmata Posted November 26, 2003 Author Posted November 26, 2003 Hi!Allready tried that...Doesn´t work!!! :-/Maybe I´m forgot something...??Or maybe I´m just stupid.. ;)Christoffer
TK. Posted November 26, 2003 Posted November 26, 2003 Could you try the MIDImon application? It should display the correct BPM - if not, check your Cubase setup.Note that MIOS V1.4b is required to get this working!Best Regards, Thorsten.
Stigmata Posted November 26, 2003 Author Posted November 26, 2003 Yeah!!Working ;D ,The problem was I got the MIOS ver.1.3..Another question:The rate (in the WT menu) how do you know that the value should be 123 for 16th note?If I want it to be 4th note?? Do I have to be an matematic professor or something?? ;)Thanks!!!!Christoffer
TK. Posted November 27, 2003 Posted November 27, 2003 I've planned to improve this in the future (do avoid more questions regarding this topic ;-)Best Regards, Thorsten.
pay_c Posted November 27, 2003 Posted November 27, 2003 Maybe a big "what to do if it doesn´t work" - FAQ would be helpful, wouldn´t it? There are often questions coming up again and again (like that "I´m getting random data" - AIN question and stuff).Idea?
Stigmata Posted November 27, 2003 Author Posted November 27, 2003 (do avoid more questions regarding this topic sorry :-[ ;)Christoffer
