folly Posted September 22, 2014 Report Posted September 22, 2014 I WANT set to an encoder, 2 control change EXAMPLE; turning left CC = 1; turning to the right CC = 2 how you doing? thank!
folly Posted September 25, 2014 Author Report Posted September 25, 2014 (edited) there is no one who understands my problem? :sad: :question: Edited September 25, 2014 by folly
TK. Posted September 25, 2014 Report Posted September 25, 2014 I understand the problem, but I can't provide a solution (yet) Best Regards, Thorsten.
TK. Posted September 28, 2014 Report Posted September 28, 2014 I just remember that there is a solution! :) -> http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fconev_1.ngc Best Regards, Thorsten.
folly Posted September 28, 2014 Author Report Posted September 28, 2014 THANK YOU THORSTEN! Then do the tests then tell you how it goes. Regards, Silviu.
folly Posted September 28, 2014 Author Report Posted September 28, 2014 I run this setup default.ngc and everything works great ..(encoder ALPS 24 pp- detent). thanks Thorsten. ENC n= 4 sr= 9 pins=6:7 type=detented3 EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x01 type=CC cc=96 lcd_pos=1:1:2 label="Enc INC" EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x7f type=CC cc=97 lcd_pos=1:1:2 label="Enc DEC" Best Regards
