pattern change in sync with elektron analog rytm.
benwa
hi everybody, it s my first post on this forum, a friend just build a midibox sequencer v4 for me, and the first thing i really can t do is how to change the pattern on theidibox at the same time i change mattern on my elektron analog
rytm
i know that analog rytm send program change on channel 14, i d like to keep the analog rytm as master but if it s not possible i would change.
i tried with the mixer map but was not able to associate a map with a pattern,
i hope someone will be able to help me and hope you will understand my bad english :-)
you can configure this in the MENU->MIDI "Ext. Ctrl" page.
With GP Button 12 select the "PrgChange" function, and set the mode to "Pattern".
In the same page you can define the MIDI IN port and Channel over which the Program Change event should be received.
