FantomXR Posted November 3, 2014 Posted November 3, 2014 Hey, here is the situation: I've a keyboard which has a AINSER8 inside. I soldered a jack to it for a switch. The switch works flawlessly. I configured ain_mode=switch. So it sends 127 when pressed and 0 when depressed. What I want to achieve is, to send 127 when I press it the first time.... release it... press again and it should send 0. I tried various things with NGR-commands... but I didn't get it to work. Any suggestions here? Thanks, Chris
TK. Posted November 3, 2014 Posted November 3, 2014 Hi Chris, I haven't checked this by myself, but it could work by forwarding the event to a BUTTON in toggle mode Best Regards, Thorsten.
FantomXR Posted November 3, 2014 Author Posted November 3, 2014 (edited) Hi Thorsten, I tried this: EVENT_AINSER id=65 ain_mode=Switch fwd_id=BUTTON:1001 EVENT_BUTTON id=1001 button_mode=Toggle type=cc cc=1 without success. MIOS doesn't monitor anything. You already wrote in this thread: that only a value is forwarded with fwd_id but it won't trigger a midi event. Maybe that's there is the problem? Edited November 3, 2014 by FantomXR
TK. Posted November 3, 2014 Posted November 3, 2014 You are right, looking into the source code I can confirm that I even commented this behaviour ;-) Seems that we've finally found a use case where it makes sense to think about a generic way to trigger the MIDI event during forwarding. However, as always it will take some time until such a new feature will be available. Until then you could just execute a .NGR section with the AINSER event in addition, and from there you can send the current button value (which toggles between min and max) with the "TRIGGER BUTTON:<button-id>" command. Best Regards, Thorsten.
FantomXR Posted November 3, 2014 Author Posted November 3, 2014 (edited) Hey TK, thanks! I will try this. Maybe it's easier for you to implement another ain_mode named "toggle" so adding a MIDI trigger wouldn't be necessary. Edited November 3, 2014 by FantomXR
FantomXR Posted November 4, 2014 Author Posted November 4, 2014 (edited) Hey Thorsten, I tried the following NGR: ### Leslie Switch ### if ^section == 6 if AINSER:67 == 127 trigger BUTTON:17 endif endif and NGC: EVENT_BUTTON id=17 button_mode=Toggle fwd_id=LED:17 type=cc cc=1 EVENT_AINSER id=67 ain_mode=Switch type=meta meta=runsection:6 If I now press the sustain switch, it just sends out CC 1 with value 0. But not 127. Where is my mistake? Edited November 4, 2014 by FantomXR
TK. Posted November 4, 2014 Posted November 4, 2014 Let me follow-up on this later (when I implemented the new mode...) Best Regards, Thorsten.
TK. Posted November 9, 2014 Posted November 9, 2014 I added "ain_mode=Toggle", because it was easier to implement this than troubleshooting your experiment ;) The new feature is available in v1.032 Best Regards, Thorsten.
