bill Posted November 21, 2014 Report Posted November 21, 2014 (edited) Hello all, I'm trying to 'make' my 8bit app hex (skeleton), on a fresh ubuntu 14.04 installation, but i have some newbie troubles. Here's my console output e6440@e6440-Latitude-E6440:~/MIOS/sdcc_skeleton_v1_1$ make rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output sh ./bin/mios-gpasm -c -p p18f452 -I./src -I ./include/asm -I ./include/share -I ./modules/debug_msg -I ./modules/app_lcd/dummy -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I ./modules/mios_wrapper modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o ./bin/mios-gpasm: 24: ./bin/mios-gpasm: declare: not found ./bin/mios-gpasm: 27: ./bin/mios-gpasm: declare: not found ./bin/mios-gpasm: 37: ./bin/mios-gpasm: Syntax error: "(" unexpected (expecting "fi") make: *** [_output/mios_wrapper.o] Error 2 I have installed sdcc/gputils, (http://www.midibox.org/dokuwiki/doku.php?id=installing_gputils_and_sdcc_on_ubuntu_8.04) and changed my profile as stryd suggest here : Can anyone help ? Cheers Edited November 21, 2014 by bill Quote
sneakthief Posted November 21, 2014 Report Posted November 21, 2014 (edited) If I'm not mistaken, you need to use bash instead of sh: http://unix.stackexchange.com/questions/17727/why-does-my-shell-script-give-the-error-declare-not-found http://ubuntuforums.org/showthread.php?t=1658965 I find Googling compiler error output often very helpful. Edited November 22, 2014 by sneakthief Quote
bill Posted November 22, 2014 Author Report Posted November 22, 2014 Thanks sneakthief ! You were right, and i must confess that i did not search very hard... In common.mk i found this comment/solution : # if MIOS_SHELL environment variable hasn't been set by the user, set it here # Ubuntu users should set it to /bin/bash from external (-> "export MIOS_SHELL /bin/bash") I also found many answer to my problems here : :) Quote
