pcbatterij Posted December 26, 2014 Posted December 26, 2014 Hey all, Has anybody had a problem compiling the seq V4 firmware with the ui_store_file_required ? I keep having "UNDIFINED REFERENCE TO 'ui_store_file_required' I am using the latest files on the SVN? does anybody have an idea what this might couse? cheers, Jef
pcbatterij Posted December 26, 2014 Author Posted December 26, 2014 I have looked further and my guess is that in ui.c there should also be: u8 ui_store_file_required; cheers,
kpete Posted December 26, 2014 Posted December 26, 2014 Jef - I don't know whats going on with this but I find the define located in "seq_ui.c" file with a reference in "seq_ui.h". The revision header for seq_ui.c is: // $Id: seq_ui.c 2102 2014-12-15 17:40:04Z tk $ I got this information directly from the SVN.MIOS32 repositories on line. Are you using version 2102 for that file which was changed on 15-Dec? Pete
pcbatterij Posted December 26, 2014 Author Posted December 26, 2014 Pete, thx for the reply. I have been having a few problems with SVN, but I can see the latest version now, and you are right it was already in there. my bad cheers, Jef
kpete Posted December 27, 2014 Posted December 27, 2014 (edited) I understand about your problems with the SVN. I just don't have enough experience in using it. The most I have done is do diff's between the original version that is stored on my PC. I'm too afraid to try to do an update in my sandbox for fear that I will have problems with merging changes in the same files that others have changed. From my previous knowledge with version control systems I know it can be done but I just don't need it for what I am doing. It is nice that TK has used a naming convention that helps pin point where the variable or function is located. Pete Edited December 27, 2014 by kpete
TK. Posted December 30, 2014 Posted December 30, 2014 Here a hint how you can retrieve the changes from an "official place" in order to get an impression about possible reasons for such issues. Go to http://svnmios.midibox.org Select the MIOS32 repository, and then click on the "View logs" button. Check the comments, they are sometimes helpful. Select the potential problematic version with a "known good" one, or whatever you want to compare. Then click on the "show changed files" button: This gives you a nice looking diff over all changes: And with some luck you will find out quickly, that the variable has been declared in seq_ui.c :) I'm using this web based method as well whenever somebody reports a problem after firmware changes in order to find out what I did ;-) Best Regards, Thorsten.
