This is a resistor ladder on a Dout module that can produce Controlable Voltage that midibox sequencers can handle
;; DOUT 160k
;; D7 ---o---/\/\/\---*
;; 80.6k |
;; D6 ---o---/\/\/\---*
;; 40.2k |
;; D5 ---o---/\/\/\---*
;; 20.0k |
;; D4 ---o---/\/\/\---*
;; 10.0k |
;; D3 ---o---/\/\/\---*
;; 5.1k  |
;; D2 ---o---/\/\/\---*----CV Out-----------------------------------o ( 0v <----> +5v )
;; 220 Ohm
;; D1 ---o---/\/\/\--------o free assignable trigger
;; 220 Ohm
;; D0 ---o---/\/\/\--------o another free assignable trigger
__________________________________________________________________________
What i wanna ask here is..
How can i use a shift register with a resistor ladder as that.. but with higher voltages.. i need to go from 0 to +15v
I need to use a different from 74HC595 that DOUT uses or is there another way?
I saw something similar before but i am not so sure.. maybe a TL074 can do the job like that in this image:
Regards, Tilemachos
Edited by Navicat
Thank you for your answer!
I know about Aout_LC and is really similar to that i want!
But i need something different and i am really sorry i did not explain!
What i wanna build is a module with with up to 8 CV channels that i will use to control the velocity on a TR-808 clone...
Velocity on a TR-808 is a Trigger pulse of 1ms width with voltage from +5 and +15
Here is my idea taken from another project.. will this work?
To get higher voltage, you need to configure the tl074 for some gain.
You do this by adding a voltage divider to the feedback loop of the op-amp.
eg. 20k between output and "-" and 10k between "-" and GND.
If you don't need those pulses at the same time, this could work.
You need to feed  A and B with address bits, though. C can stay low, since you only use 4 Outputs.
That's what i meant.
Do you need any voltages between +5 and +15, or just those two values?
If it's just 5V and 15V, there is an easier soulution:
You could use two DOUT pins per instrument, one going directly to the trigger-in and another going to a ULN2803 or similar, so it gets amplified to 15V and then to the trigger-in.
Thank you very much for help me understand this!!!
No i need any voltages between 0 and 15 volts with as much as high resolution i can get.. but 8-bit is ok!!
Here is an example!! Thanks for your help!
0 volts in = 0 volts out
1 volts in = 3 volts out
3 volts in = 9 volts out
3.5 volts in = 10.5 volts out
until i go up to
5 volts in = 15 volts out
That's amazing!!!
Regards Tilemachos
This has a gain of 1.5, to get a gain of 3 2k and 1k have to be switched.
Since the op-amp will never have to put out negative voltages, you could connect its negative supply to gnd instead of -15V.
You will need a little more than +15V on the positive supply, because else the op-amp can't reach +15V on its output.
Ok man now i am sure that it will work!
The same thing i'm trying to do is used in the TR-909 circuit! You are really amazing you answered as roland did it in the past!
Take a look!
Ok i made a schematic for an 8x CV OUT and i need verification.. The R-2R ladder values are 20k and 10k.
One more thing i wanna ask is.. Can i drive J19 on mbhp_core_stm32f4 to work as the J8/9 and connect more Dout and DIN chain?
Here is the schematic for my DOUT with DAC and op-amps to get signal up to +15V :
http://www.docdroid.net/ri8z/dout-cv.pdf.html
Regards Tilemachos
