Saschaaa Posted March 16, 2015 Report Share Posted March 16, 2015 Hey, I'm trying to get the DIN-Module working with some of my Encoders, but it doesn't work. I have 1 Encoder (EN11-VSM1BF20) connected to the 10th and 11th Pin (D0,D1) of the first SR. This Encoder is also connected to 2 10K resistors. The other Pins (D2,D3,D4,D5,D6,D7) are only connected to other 10k resistors. I use the following code: int enc; for(enc=0; enc<NUM_ENCODERS; ++enc) { u8 pin_sr = enc >> 2; // each DIN SR has 4 encoders connected u8 pin_pos = (enc & 0x3) << 1; // Pin position of first ENC channel: either 0, 2, 4 or 6 mios32_enc_config_t enc_config = MIOS32_ENC_ConfigGet(enc); enc_config.cfg.type = DETENTED2; // see mios32_enc.h for available types enc_config.cfg.sr = pin_sr; enc_config.cfg.pos = pin_pos; enc_config.cfg.speed = NORMAL; enc_config.cfg.speed_par = 0; MIOS32_ENC_ConfigSet(enc, enc_config); } NUM_ENCODERS is 1. And in the ENC_Notify_Change App it says: MIOS32_BOARD_LED_Set(0x0001, ~MIOS32_BOARD_LED_Get()); // determine relative value: 64 +/- <incrementer> int value = 64 + incrementer; // ensure that value is in range of 0..127 if( value < 0 ) value = 0; else if( value > 127 ) value = 127; // send event MIOS32_MIDI_SendCC(DEFAULT, Chn1, 0x10 + encoder, value); But if I'm moving the Encoder, nothing happens. If the other free pins aren't connected to their 10k resistors, the ENC_Notify_Change App is called randomly and sends random values over the DEFAULT Midi Port. Also the LED is blinking randomly.... I soldered the Module twice, changed all the components, tried different tutorials(14, 15) but yet it still doesn't work :( Has anyone some tips ? Quote Link to comment Share on other sites More sharing options...
Phatline Posted March 16, 2015 Report Share Posted March 16, 2015 maybe this bring you some input: Quote Link to comment Share on other sites More sharing options...
TK. Posted March 16, 2015 Report Share Posted March 16, 2015 Hi, connected to the 10th and 11th Pin (D0,D1) of the first SR D0 is located at pin 11, and D1 at pin 12 See also http://www.ucapps.de/mbhp/mbhp_dinx4.pdf It would be interesting if MIDIO128 outputs MIDI events if you turn the encoder (each pin should send an individual note event) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Saschaaa Posted March 16, 2015 Author Report Share Posted March 16, 2015 Hi, sorry, typing error: they are connected at pin 11 and 12. MIDIO128 sends no output if i turn the encoder. And i think it's no format error like it the example above, because if it would be so, it would output anything. At the moment there is no output. Only If some of the unused pins aren't connected to their resistors, the Debug-Section outputs something like this: Value:3 Encoder:1 Inkrementer:P Value:3 Encoder:0 Inkrementer:P Value:4 Encoder:0 Inkrementer: Value:3 Encoder:1 Inkrementer:P Value:4 Encoder:1 Inkrementer: As a result of this in the ENC-Notify-App: MIOS32_MIDI_SendDebugMessage("Encoder: %u", encoder); MIOS32_MIDI_SendDebugMessage("Inkrementer: %s", incrementer); MIOS32_MIDI_SendDebugMessage("Value: %u", value); Any more tips ? Quote Link to comment Share on other sites More sharing options...
TK. Posted March 16, 2015 Report Share Posted March 16, 2015 Previously you wrote that NUM_ENCODERS is 1, now encoder == 1 will be print (means: the second encoder, because encoders are counted from 0) However: remove (or disable) the encoder configuration and print debug messages from APP_DIN_NotifyToggle() instead - what happens? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Saschaaa Posted March 16, 2015 Author Report Share Posted March 16, 2015 Sorry again, i have 2 Encoders connected: 1 to 11/12 the other to 13/14 The other 4 pins are connected to 10k resistors If i disable the encoder configuration and write : MIOS32_MIDI_SendDebugMessage("Pin: %u", pin); MIOS32_MIDI_SendDebugMessage("Value: %u", pin_value); in the DINN_Notify_Toggle App - nothing happens However, the DebugSection sent once the following(but now not anymore, don't know why): Pin:50 Value:0 Pin:50 Value:1 Pin:28 Value:0 Pin:28 Value:1 Pin:12 Value:0 Pin:12 Value:1 Pin:86 Value:0 Pin:86 Value:1 Pin:65 Value:0 Pin:65 Value:1 Pin:106 Value:0 Pin:106 Value:1 (it continued with the following pins:55,85,62,21) Quote Link to comment Share on other sites More sharing options...
Saschaaa Posted March 18, 2015 Author Report Share Posted March 18, 2015 Hey, it's me again... As the DIN-Module still isn't working, I tried to get the DOUT-Module connected. I soldered the DOUTX4_R5 Schematic with only one IC (74HC595) and left the 9th pin open(don't know if that's correct) ?! After that, I connected 2 LEDS to D0 and D1 and uploaded the DOUT-Tutorial (9) Now I can see the LEDs in full color, but I can't toggle them as i should be, while playing a C2 for example... Has anyone some suggestions ? Quote Link to comment Share on other sites More sharing options...
TK. Posted March 18, 2015 Report Share Posted March 18, 2015 So, neither DIN nor DOUT is working - could the problem be located at the core module? Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Saschaaa Posted March 19, 2015 Author Report Share Posted March 19, 2015 (edited) Hey, i think the same... the problem is located at the core. Therefore I used the LogicAnalyzer to visualize the Dataoutput of the 74HCT541, maybe you can see there something irregular. In every picture i took, the first 6 signals show the following: D0 = FirstPin 74HCT541 (OE#), D1 = 19thPin 74HCT541(OE#), D2 = 11th Pin 74HCT541(Y7), D3 = 12th Pin 74HCT541 (Y6), D4 = 13th Pin 74HCT541(Y5), D5 14th Pin 74HCT541(Y4) Pic 1 - 3 show additionaly on D6 = Second Pin(A0), D7 = Third Pin(A1) Pic 4 - 6 show additionaly on D6 = 4th Pin(A2), D7 = 5th Pin(A3) Pic 7, 8 show additionaly on D6 = 6th Pin(A4), D7 = 7th Pin(A5) Pic 9 - 11 show additionaly on D6 = 8th Pin(A6), D7 = 9th Pin(A7) On Pic 1,9,11 you can also see that I played a Note in MIOS-Studio (D2) Link: http://workupload.com/file/1oKw0gde best regards, sascha Edited March 19, 2015 by Saschaaa Quote Link to comment Share on other sites More sharing options...
Saschaaa Posted March 23, 2015 Author Report Share Posted March 23, 2015 (edited) Hey, i know the pics above may be a bit confusing so I took some new ones. At the moment, i'm trying to get the DOUT-Module (not the DIN) working. I measured the following on the 541: PB12, Slave/Chip-Select signal D0 PB13, SCK D1 PB15, MOSI -> data D2 Y7 D3 Y6 D4 Y5 D5 PB14 MISO D6 Now connecting the core with the DOUT-Module results in an activated LED In pic 1, i played a G-0, which toggled the LED off In pic 2, i played a C2, which resulted in nothing The things I don't get are the following: 1) Why is a played G-0 such a long impuls ? That only happended at G-0. All other notes i played were just short impulses. 2) Powering the core results in an activated CORE-LED. Playing Midi-Notes toggles the CORE-LED off, but normaly, it should be the other way around, shouldn't it ? If i restart the core with the black button, this doesn't change. If i load the code again on the core via the MIOS-Studio, the CORE-LED goes off and behaves, like it should be(incoming Midi-Message ->LED ON). However, the DOUT-LED is still ON. 3) If only 1 595 is connected to the DOUT-Module, where should pin 9 (O8) go ? 4) Why has the signal of the SCK pin so much bytes ? Because you could control up to 128 LEDs with it ? So 128 Bits ? What if i just want to control 16 LEDs? Is that changable ? http://www.pic-upload.de/view-26499121/print_17.jpg.html http://www.pic-upload.de/view-26499159/print_18.jpg.html I hope somebody can help me... Best regards, Sascha Edited March 23, 2015 by Saschaaa Quote Link to comment Share on other sites More sharing options...
