The question was related to MIDIbox NG.
Here a configuration example for 4 banks: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fencbanks.ngc
It shows how to send different CCs, but you could change the configuration to select different channels instead.
E.g. instead of:
# Bank 2
EVENT_ENC    id= 17  hw_id =  1  bank=2  fwd_id=LED_MATRIX:1    fwd_to_lcd=1  type=CC     chn= 1 cc= 32   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:1:2)%B"
EVENT_ENC    id= 18  hw_id =  2  bank=2  fwd_id=LED_MATRIX:2    fwd_to_lcd=1  type=CC     chn= 1 cc= 33   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:2:2)%B"
EVENT_ENC    id= 19  hw_id =  3  bank=2  fwd_id=LED_MATRIX:3    fwd_to_lcd=1  type=CC     chn= 1 cc= 34   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:3:2)%B"
write:
# Bank 2
EVENT_ENC    id= 17  hw_id =  1  bank=2  fwd_id=LED_MATRIX:1    fwd_to_lcd=1  type=CC     chn= 2 cc= 16   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:1:2)%B"
EVENT_ENC    id= 18  hw_id =  2  bank=2  fwd_id=LED_MATRIX:2    fwd_to_lcd=1  type=CC     chn= 2 cc= 17   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:2:2)%B"
EVENT_ENC    id= 19  hw_id =  3  bank=2  fwd_id=LED_MATRIX:3    fwd_to_lcd=1  type=CC     chn= 2 cc= 18   range=  0:127 offset=  0  ports=1000100000001000  lcd_pos=1:1:1  label="ENC #%3i    %3d@(1:3:2)%B"
THANK YOU  TK!!
I try then I tell you.
with a single button I can change bank 1 and bank 2?
Yes.
The example shows:
EVENT_BUTTON id=2000  type=Meta   meta=SetBank   button_mode=OnOnly range=1:1
With:
EVENT_BUTTON id=2000  type=Meta   meta=SetBank   button_mode=OnOff range=0:1
the button would set the second bank when press, and the first bank when depressed
Or with:
EVENT_BUTTON id=2000  type=Meta   meta=SetBank   button_mode=Toggle range=0:1
the button would toggle between the first and second bank
