alfadeo Posted May 1, 2015 Report Posted May 1, 2015 I am new to Midibox (just ordered parts for a Midibox SEQ) and wonder if it is possible to send program changes a few ticks ahead of time. I want to use program changes to change patterns on Elektron boxes (Octatrack and Monomachine). Unfortunately they do not change patterns immediately, but wait (depeding on settings) e.g. until the next bar after the PC event. Ideally I would like to select Elektron patterns by setting PCs at the first step of each pattern, but that would require that they are sent a few ticks ahead of time, so that pattern changes occur at the beginning of the new pattern (and not one bar later). So far I have found no hardware sequencer (except Elektrons) that sends PCs ahead of time. Is that possible with the Midibox SEQ? I have found nothing in the manual and the forums, but might have missed something. I also would not mind adjusting code, if MIDI scheduling allows to send events ahead of time. Best, Christoph
Rowan Posted May 1, 2015 Report Posted May 1, 2015 I'll have a look into this for you as I have a Machinedrum, Octoatrack and a MBSEQ.
cosmosuave Posted May 3, 2015 Report Posted May 3, 2015 I am using a Machinedrum where I use midi notes to change the patterns not sure if it is the same for the MM or Octatrak...
alfadeo Posted May 8, 2015 Author Report Posted May 8, 2015 Yes MM can change patterns with midi notes, but not the Octatrack ...
cube48 Posted May 10, 2015 Report Posted May 10, 2015 If I remember correctly PC is just a CC so it should be possible with CC layer.
alfadeo Posted May 18, 2015 Author Report Posted May 18, 2015 But I need to send PCs a few ticks in advance (ie before pattern start) to change OT patterns at the first step of the next pattern. Otherwise patern changes will be delayed e.g. by a bar (depending on OT setings). Programming PCs at the pattern end is not a real solution, because after a single repetition loops will be out of sync again.
cosmosuave Posted May 18, 2015 Report Posted May 18, 2015 Check in the documentation for Mixer Map... When I first started using the SEQV4 I was using that page to perform program changes and it would allow you on a per step basis to enter the PC... This may work for you... Now all I do is enter it under Track Event Config... Sorry i don't have a definitive answer fro you... bri.
