=FFW=> Posted May 7, 2015 Posted May 7, 2015 Hi Forum, while skimming over this thread: i asked myself, if it would be possible, to connect a usb-midi keyboard to the SeqV4 and use it as an input when reading this (quote from TK.): "The update will be available with all future MIOS32 applications, it's always available without special configuration." Has anyone tried that or is it not possible to run the SeqV4 application along with the USB Midi Host mode? Cheers and thanks, FFW
eptheca Posted May 7, 2015 Posted May 7, 2015 I have my MBCV V2 connected to the SEQ V4 in USB MIDI host mode It runs fine I haven't connected a keyboard, but it should work the same. Since a USB hub is not supported, only one thing can be connected at a time
Rowan Posted May 7, 2015 Posted May 7, 2015 Yes, it works. Just plug in your USB MIDI device before you power on the SEQ V4.
=FFW=> Posted May 7, 2015 Author Posted May 7, 2015 (edited) hey rowan (and eptheca) - great news! i see you are very happy and knowledgeable with the seq :-) cheers! Edited May 7, 2015 by =FFW=>
