82Studio Posted May 27, 2015 Posted May 27, 2015 Hi, I'm interested to create controller with 24 motorfaders. 8 motorfaders in MF NG module. I've seen in MF NG Module page it's possible to cascading "to chain multiple module" but how ? With midi socket ? How is recognised the installation ? Thanks !!
novski Posted May 27, 2015 Posted May 27, 2015 Hi Yes, MF_NG can be connected to a chain of 4 Modules. It workes by connecting the midi out port to the in port of the second module and so on. But befor you will have to connect it with your Computer and set the Modul 1-3 to the Link through mode with Mios Studio MF Tool. The last Module you will have to set as End Point Module. Also the Protocol has to be set Right. Take a read in the Manual of http://ucapps.de/midibox_ng_manual.html Best Regards Ivan
novski Posted May 27, 2015 Posted May 27, 2015 Have a look to this almost at the bottom you can find the chapter MF... http://ucapps.de/midibox_ng_manual_ngc.html
82Studio Posted July 30, 2015 Author Posted July 30, 2015 Thanks for informations, In the meantime, I've ever read this about linking core modules (possibility of Midi loop error). I'm surprised so see an option for touchsensor, in the forum I've seen it was not implemented . Can you confirm me touchsensors work fine with MF NG Module ? Best Regards Vince
Zam Posted July 30, 2015 Posted July 30, 2015 depending of fader, there is a report somewhere, at my side I confirm ALPS work fine with MF_NG
82Studio Posted August 4, 2015 Author Posted August 4, 2015 I don't take any risk, I use ALPS RAS0N 11M9 fader, like TK specs ! Thanks !
