Phatline Posted June 21, 2015 Posted June 21, 2015 (edited) i want the to adjust the exact RPM of my Blender (up to 37500 rpm) via a menu encoder i want to setup the exact hz, the code displays then the RPM value, the leds connected to a dout-module begin to flash the combinations of different Dout-pins to one LED give the led more Current... dont know up to know... maybe i need this. i now have to adjust the speed off the blender until the rotor seems to not moving anymore some basics? if (RPM==Blinkfrequency) {there will be No Motion} RPM=Rotation per minute 1minute has 60000ms RPms=Rotation per ms 1RPM is 60000RPms 38000RPM is 2280000000RPms u32 range is=4294967295 1hz = 60RPM 38000RPM = 633Hz so the maximal range of this strobo will be arround 640hz Frequency=1/Time Time=1/Frequency 1000hz = 1ms the protone resonance frequency of hydrogen (H) = 61779498184847720448 Hz the 58 Octave from this is 428.681 Hz taken from the free m.rauch software: http://aladin24.de/htm/res/index.php 428,681hz = 25720,86 RPM --- this is the speed i want to setup the mixer with water in it. Time= 1/428,681hz = 0,002161316s x 1000 = 2.1613ms that meens that void APP_Tick(void) is not accorate for this, since it is called evy 1ms the standart updaterate ot the void APP_SRIO_ServicePrepare(void){ //called before the shift register chain is scanned MIOS32_DOUT_PinSet( 0, LEDvalue[0]);} is 1,28uS which is accourate enough to handle the LED-Status u32=4294.967.295 wordlength. seco.milis.mikro I think thats enough so set up a timer @1uS rate: void APP_Init(void){ //initialize MIOS32_TIMER_Init(1, 1, Timer, MIOS32_IRQ_PRIO_LOW); //1uS Timer set then count (timecount) to a specific time... when reached: reset the counter, turn on the led... the counter now counts again a specific time until it reaches the decay--time-mark (here 100uS) now it turn off the LEDs ...now it counts forwarde to the specific time...reset the counter, turn on the led.... void Timer(){ timecount = timecount + 1; if (timecount >= time) {LEDvalue[0] = 1; timecount = 0;} if (timecount >= decaytime) {LEDvalue[0] = 0;}} next time some menus, encoders, display, and formulars... for what a ocataved protone resonancy frequency on water? hmm someone sayed that on this frequency the temperature drifts down and water got lost... i want to proove that! Edited June 22, 2015 by Phatline
Hawkeye Posted June 23, 2015 Posted June 23, 2015 You are positively insane, man! :phone: :phone: :phone: Have a great day! Peter
Phatline Posted June 26, 2015 Author Posted June 26, 2015 hmmm... the timer or the shiftregister update are not working as i want... i want a stable blink...instead, it sometimes some blinks dont accour... it looks like the counter overlaps with the shiftregister update or so...maybe it is a priority question --- any idea? here is the code: (attached is also the full project - it runs on a lp17 core with dio-shiftregisters connected-dout register 1 pin 0 is the blink-output... the din register 1 pin 0+1 = hz-encoder.... the used display is 2x40 signs...) #include <mios32.h> #include <FreeRTOS.h> #include <task.h> #include "tasks.h" #include "file.h" #include "app.h" #include <portmacro.h> #include <queue.h> #include <semphr.h> #include <string.h> #include "mios32_timer.h" #define NUM_ENCODERS 9 //5 Menue Encoders are connectet const mios32_enc_config_t encoders[NUM_ENCODERS] = {//(SR begin with 1, ENC with 0) // setup the Pinout of that Encoders { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=1, .cfg.pos=0 }, //Menue Encoder 0 - only virtual, since they are mapped to differnt Variables... { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=1, .cfg.pos=2 }, //Menue Encoder 1 - ...if "Menue Page Encoder" has changed { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=1, .cfg.pos=4 }, //Menue Encoder 2 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=1, .cfg.pos=6 }, //Menue Encoder 3 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=2, .cfg.pos=0 }, //Menue Encoder 4 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=2, .cfg.pos=2 }, //Menue Encoder 5 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=2, .cfg.pos=4 }, //Menue Encoder 6 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=2, .cfg.pos=6 }, //Menue Encoder 7 { .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=4, .cfg.sr=3, .cfg.pos=0 },}; //Menue Page Encoder xSemaphoreHandle xLCDSemaphore; // take and give access to LCD u32 MenueUpdateCount = 0; u32 value = 0; //Encoder calculation... u32 i = 0; //Encoder calcualtion //WKS u32 hz = 428; u32 nm = 10; u32 rpm = 25680; u32 time = 2161; //setup timer time u32 timecount = 0; u32 hzcount = 0; u32 decaytime = 128; //Task Prioritys #define MUTEX_LCD_TAKE { while( xSemaphoreTakeRecursive(xLCDSemaphore, (portTickType)0) != pdTRUE ); } //a Mutex reserve a Resoure (LCD or SD-Card) for a task, until it is given away... #define MUTEX_LCD_GIVE { xSemaphoreGiveRecursive(xLCDSemaphore); } #define PRIORITY_StoreLoad ( tskIDLE_PRIORITY + 2 ) //3:Mios standart static void StoreLoad(u8 tick, u16 order); static void Timer(void); void APP_Init(void){ MIOS32_BOARD_LED_Init(0xffffffff); //initialize all LEDs xLCDSemaphore = xSemaphoreCreateRecursiveMutex(); //create Mutex for LCD access //initialize encoders i = counter for(i=0; i<NUM_ENCODERS; ++i) MIOS32_ENC_ConfigSet(i, encoders[i]); //initialize encoders MIOS32_TIMER_Init(1, 1, Timer, MIOS32_IRQ_PRIO_HIGH); //1uS Timer set MIOS32_SRIO_ScanNumSet(1); // limit the number of DIN/DOUT SRs which will be scanned for faster scan rate //speed up SPI transfer rate (was MIOS32_SPI_PRESCALER_128, initialized by MIOS32_SRIO_Init()) MIOS32_SPI_TransferModeInit(MIOS32_SRIO_SPI, MIOS32_SPI_MODE_CLK1_PHASE1, MIOS32_SPI_PRESCALER_64); // prescaler 64 results into a transfer rate of 1 uS per bit // when 2 SRs are transfered, we are able to scan the whole 16x8 matrix in 300 uS } void Timer(){ timecount = timecount + 1; if (timecount > time) {MIOS32_DOUT_PinSet( 0, 1); timecount = 0;} if (timecount > decaytime) {MIOS32_DOUT_PinSet( 0, 0);}} void APP_Background(void){} void APP_Tick(void) { //1ms Event Triggering MenueUpdateCount = MenueUpdateCount + 1; if(MenueUpdateCount > 650){MenueUpdateCount = 0; StoreLoad(0, 0);}} //update the Menue void APP_MIDI_Tick(void){} void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package){} void APP_SRIO_ServicePrepare(void){} void APP_SRIO_ServiceFinish(void){} void APP_DIN_NotifyToggle(u32 pin, u32 pin_value){} void APP_ENC_NotifyChange(u32 encoder, s32 incrementer){ if(encoder == 0){ value = hz + incrementer; // increment to virtual position and ensure that the value is in range 0..127 if(value < 0) {value = 999;} if(value > 999){value = 0;} hz = value; time = 1000000/hz; //we count in mikro Sekonds! rpm = hz * 60; } if(encoder == 2){ value = time + incrementer; // increment to virtual position and ensure that the value is in range 0..127 if(value < 0) {value = 3000;} if(value > 3000){value = 0;} time = value; hz = 1000000/time; rpm = hz * 60; } if(encoder == 4){ value = rpm + incrementer; // increment to virtual position and ensure that the value is in range 0..127 if(value < 0) {value = 100000;} if(value > 100000){value = 0;} rpm = value; hz = rpm / 60; time = 1000000/hz; } if(encoder == 7){ value = (incrementer * 2) + decaytime; // increment to virtual position and ensure that the value is in range 0..127 if(value < 0) {value = 99999;} if(value > 99999){value = 0;} decaytime = value; } } void APP_AIN_NotifyChange(u32 pin, u32 pin_value){ //AIN - - Potentiometer has mooved - - Analog InPut } static void StoreLoad(u8 tick, u16 order){ //Display MENUE, Store+Load Bank & Sys-Config if(tick == 0){//Menue MUTEX_LCD_TAKE; //request LCD access MIOS32_LCD_Clear(); //clear screen //1st Line = Encoder Variables....change something! MIOS32_LCD_CursorSet(0, 0); MIOS32_LCD_PrintFormattedString("%d", hz); MIOS32_LCD_CursorSet(10, 0); MIOS32_LCD_PrintFormattedString("%d", time); MIOS32_LCD_CursorSet(20, 0); MIOS32_LCD_PrintFormattedString("%d", rpm); MIOS32_LCD_CursorSet(35, 0); MIOS32_LCD_PrintFormattedString("%d", decaytime); //2nd Line = Menue Describtio MIOS32_LCD_CursorSet(0, 1); MIOS32_LCD_PrintFormattedString("%s", "hz"); MIOS32_LCD_CursorSet(10, 1); MIOS32_LCD_PrintFormattedString("%s", "usec"); MIOS32_LCD_CursorSet(20, 1); MIOS32_LCD_PrintFormattedString("%s", "rpm"); MIOS32_LCD_CursorSet(35, 1); MIOS32_LCD_PrintFormattedString("%s", "decay"); MUTEX_LCD_GIVE;}} // release LCD access for other tasks RPM_BLINK.zip
