Synergic Posted December 12, 2003 Posted December 12, 2003 hi!i´m thinking about build usb molude after a finish my midibox 64.it has 2 midi in ...could i use bothof them??could i let stuffed optoacouplers when i´m not using midi ins?? it look like i couldn´tthanks ;D
LO Posted December 12, 2003 Posted December 12, 2003 Not sure if I understand your question?But yes the USB module has 2 useable midi in'sIf you are not using them you can still leave the opto's in place.
pay_c Posted December 12, 2003 Posted December 12, 2003 How to connect the USB module is stated very good on the UCApps page. (Those five pics there).So: If you make a direct link to the Midibox (over the MBLink) you mustn´t (!) stuff the optocouplers (baaad short circuit) I think. If you just use the normal INs and OUTs use those optocouplers (preferred solution due to maximum flexibility).Also hope I understood that question right... greets
Synergic Posted December 13, 2003 Author Posted December 13, 2003 ??? sorry ..my english is a rubish!!i´ll give you an example:i want to conect with usb module my midibox64(conected internally to the core using j11) and 2 midi keyboards......can i do this?and another question:when i dont use midi inputs...optocouplers can be stuffed or not??thanks!!!!
