Hello
I was checking on web another Sequencer and i just found something usefull.
Can be used in various project.
It would be great if something similar can be done for the Midibox Sequencer.
Here is the link : D-MUX
Tell me what you think and if someone in here is able to build
The implementation is unclear and the linked article doesn't exist. What do you hope to achieve? The SEQ already supports 64 (I think) assignable triggers via DOUT pins.
The DMUX is a Device to trigger Drum Machines like 606/808/909 and even modular systems.
It is a Device with :
  • MIDI: In/Out
  • 16 Trigger Out ( +5v Pulses 1ms )
  • 16 Accent Out ( Variable Voltage Out Pulses. Assignable to CC,Velocity or whatever we want. )
It uses a PIC18F2420 as a CPU
For Trigger out it uses what the DOUT system of Midibox has.
For Accent Out there is 16 CV.
The SEQ supports more DOUT that the module i talk about but does not support 16 AOUT.
Dmux support this with a 4051 chip. Can something similar can be done for Midibox?
So, MBSEQ supports 64 DOUT + 8 AOUT, while the linked device supports 16 DOUT + 16 AOUT, where is the problem? :-)
Not intended as a critical posting, just trying to understand, what the goal is?
You can always chain up a few MIDIboxes (not necessarily all of them running MBSEQ) specialized/adapted for your needs, it just needs a bit of programming, but everything is really well documented and easy to do.
Many greets!
Peter
  • Like 1
