dreamer Posted December 15, 2015 Posted December 15, 2015 Just a general question. Which caps are best to use for MBSID projects (SMD caps not ofcourse)The lower the tolerance the better?
Hawkeye Posted December 15, 2015 Posted December 15, 2015 Maybe this old thread helps! :)Many greets,Peter
dreamer Posted December 15, 2015 Author Posted December 15, 2015 i have some good caps for the SID filters but i was not talking only about the filters. But thanks for youre answer it's a very interesting topic that one.
Hawkeye Posted December 15, 2015 Posted December 15, 2015 For the non-filter parts, just about anything recently modern should do fine, they won't change the audio quality and even a high tolerance would be no problem...For some areas (power section) you will need electrolytics caps, as they are the only affordable ones with a high capacitance.Then you will need a lot of 100nF ceramics, these are small power filters in front of most ICs....Many greets,Peter
