KWK Posted January 22, 2016 Posted January 22, 2016 Hi Community, First, the midibox seq was my first DIY project, i'd like to thanks all of you, super project that gave me the fever of building hardware: an addiction is born :-) I read you a lot, and all is thanks to you. I was sequencing using a korg EMX (bad...!!), what a progress with this super Midibox Seq ! Almost all working good : STM32F4, 2x Midi I/O Module & Wilba Frontpanel. I want to add a Quad IIC module but here start the problem.. The IIC ports are not detected (Mios "System" and IICX * in the sequencer). It doesn't seam to be a connection problem (plug on J4A) : - 5V between Vd and Vs of the Quad IIC module - continuity between pin 7 of each PIC16F88 of the Quad IIC module and PB11 of the core (SD) - continuity between pin 10 of each PIC16F88 of the Quad IIC module and PB10 of the core (SC) I verified all solders on each module (Quad & Core), all seam good. The components are the rights ones too. I use the last version of the soft (V4.090), all Midi I/O ports working, no bugs detected. I don't understand why it doesn't work .. remain IIC ports not detected, and no LED working neither. Someone maybe have had the same problem ? Or can tell me what kind of test I can do to find the error ? Big thanks (and big respect) again for Midibox. Kind and warm regards Fanch
KWK Posted January 25, 2016 Author Posted January 25, 2016 (edited) Hello Community, I tried during this week-end to find out what could be the origin of the IIC detection problem. I can now affirm that is not a connection problem. But some things seam strange to me. Electrical observations (according to MBHP_CORE_STM32F4 module schematic) : When plugged on J4A : - on the core module, continuity between PB10 & PB11 (in one way only) > is this normal ? effect of D1 ? - on the quad IIC module, 5V between Vs and Vd > ok - on the quad IIC module, 3.7V between Vs and Sc > ok - on the quad IIC module, 5V between Vs and Sd > is this normal ? no effect of R8A ? I test the resistor alone, 2.2Kohm ok. --> Maybe because R7A and R8A are connected together ? Normal ? When plugged on J4B : - on the core module, no continuity between PB6 & PB9 > seams more normal to me, but different to J4A - on the quad IIC module, 5V between Vs and Vd > ok - on the quad IIC module, 3.7V between Vs and Sc > ok - on the quad IIC module, 3.7V between Vs and Sd > seams normal, but different to J4A I read that the IIC module was "Plug & Play", then I guess there is no need to boot/load a firmware for this module ? Am I right ? I'm not 100% sure ... At this time, I do nothing with the soft, only hardware building then plug. I also see the "IIC Midi sw Loopback" to test the module, but I don't have the necessary computer skill to use it ... J4B seams to have a more normal behaviour to me than J4A. But there are 4 IIC in the seq, that means only J4A is detected ? How to extend to 8 IIC midi OUT ports ? Maybe J4B would work ? Thanks all of you. Warm regards & Peace. Fanch Edited January 25, 2016 by KWK errors corrected
electrodancer Posted January 25, 2016 Posted January 25, 2016 the 4 pics need to be programmed with the iic firmware !!! if you got them from midibox webshop they should be already programed. if you got them somewhere else, they need to be programmed...before you can use the iic module.
KWK Posted January 25, 2016 Author Posted January 25, 2016 I feel like a wimp and inert dick I was assuming that with new software versions, plug and play means no programming ... without thinking that those 4 pics should be programmed too (whereas it is clearly written on ucapps website ...). Thanks a lot for you answer. I will buy (when available) to midibox shop the programmed PIC16F88... And will tell here if the only problem was this one. Btw, if someone here (for not waiting midibox shop availability - impatient mood) sells those programmed pics, I'm interested. Peace. Fanch
latigid on Posted January 25, 2016 Posted January 25, 2016 http://www.mikes-elektronikseite.de/ Funnily enough I don't think my Quad IIC is working either. I wonder if the 16Fs I bought from Mike aren't bootstrapped because I didn't ask by default...
KWK Posted January 25, 2016 Author Posted January 25, 2016 Thanks Latigid on for mikes' website. I bought on there 4 pics, and specifying for programming (fit for IIC and midibox seqv4 use). I will tell you if it works. Peace.
electrodancer Posted January 27, 2016 Posted January 27, 2016 (edited) if you send them to me (and include some money for return shipping)....i will program them. send me a PM im located in the netherlands Edited January 27, 2016 by electrodancer yess
KWK Posted February 4, 2016 Author Posted February 4, 2016 Hi community, Today I receive chips programmed from Mike. My quad IIC module is now detected by the seq, and all IIC ports work. This was the error then :) @Latigid on I added to send the firmware by e-mail to mike for him taking into account the programming. Then I guess if you don't ask anything, your PICs aren't programmed.. Thanks all Friendly regards 1
Alasdair Moon Posted April 16, 2016 Posted April 16, 2016 Same problrm here now .. Quad IIC done ... PICs from reichelt ... unprogrammed ... Wich little programmer should I buy and where do I find the code??
latigid on Posted April 16, 2016 Posted April 16, 2016 DIAMEX PIC PROG works fine and is the recommendation of TK. Or, send the PICs to one of many on the forum and we can program them for you :). I had two PICs from SmashTV (since several years) two from Mike (since a few years) and two virgin ones from Mouser. Of the pre-burned ones, one was faulty, even after erasing and re-flashing. So I'm sure the PICs from Mike had the bootloader burned in, but maybe a handling error on my side caused an issue. In any case, I have the Quad IIC working well now!
Alasdair Moon Posted April 17, 2016 Posted April 17, 2016 Just ordered a Wingoneer Pickit 2, hope this works too
Alasdair Moon Posted April 22, 2016 Posted April 22, 2016 I got my Pickit 2 today and it does scan the PIC as 16f88. But when I try to write at 5 Volt VDD I only get Errors. It works at 4 volt and 3 volt ... is that o.k.ish too ?? For the Note, .. I never ever used a PIC Programmer befor .. :)
latigid on Posted April 22, 2016 Posted April 22, 2016 If you can verify that the hex is written, it should be okay. I think the point of selecting the device (manually) is that the burner knows what programming voltage to use. 1
Rowan Posted April 22, 2016 Posted April 22, 2016 Which burning software are you using? I've got a PICKit3 and I use the Microchip software running on OSX. There is an option somewhere (I can't remember where) that you have to tell the software to power the chip while burning, it's somewhere in the advanced options IIRC.
Alasdair Moon Posted April 23, 2016 Posted April 23, 2016 I used the latest microchip software for the Pickit2 .. and it seemed to work at 3 volt .. all LEDs blink once 3-4 seconds after I power up the core
