Keeze Posted February 6, 2016 Posted February 6, 2016 (edited) Hello, Just started with Midibox. First, I want to build a controller for controlling various CC parameters in my VST's. Got the first kits from Smashtv an soldered everything together. Burned the bootloader to the CORE_STM32F4 Module and loaded the Midibox NG app. Connected a DIN and a small LED display to the CORE_STM32F4 Module. First test: print "Hello World" to LCD ...works... Second test: Connect a button ...works... Now it is time to connect a Rotary encoder... All seems to work. With the following small program: RESET_HW LCD "%CEncoder Values" # Hardware configuration ENC n=1 sr= 1 pins=0:1 type=detented1 # Events EVENT_ENC id=1 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range=0:127 lcd_pos=1:1:1 label="^std_enc" I get the folowing output in the debug-screen: [1934162.881] MBNG_ENC_NotifyChange(1, 1) [1934162.882] [EVENT] id=ENC:1 hw_id=ENC:1 bank=0 fwd_id=DISABLED:0 type=CC value=1 label=^std_enc [1934163.305] MBNG_ENC_NotifyChange(1, -1) [1934163.305] [EVENT] id=ENC:1 hw_id=ENC:1 bank=0 fwd_id=DISABLED:0 type=CC value=1 label=^std_enc [1934163.466] MBNG_ENC_NotifyChange(1, -1) [1934163.466] [EVENT] id=ENC:1 hw_id=ENC:1 bank=0 fwd_id=DISABLED:0 type=CC value=0 label=^std_enc [1934163.650] MBNG_ENC_NotifyChange(1, -1) [1934163.651] [EVENT] id=ENC:1 hw_id=ENC:1 bank=0 fwd_id=DISABLED:0 type=CC value=0 label=^std_enc The LCD outputs only a 0 or a 1. What am I doing wrong that the value does not increment or decrement? When I slide the CC16 slider in the virtual keyboard, the LCD takes over the correct value. And as soon as i touch the encoder the values flip back to 1 or 0. When I set the range to a map the values on the LCD show the values from the map correct and increment en decrement correctly. I hope that someone can shed some light on this subject... ;) Cheers, Kees Edited February 6, 2016 by Keeze
novski Posted February 6, 2016 Posted February 6, 2016 Hi Keeze I don't see a fwd_id in your config and the output seams to Disable it somehow. I don't know if that is the problem, but maybe you can add a fwd_id to test. RESET_HW LCD "%CEncoder Values" # Hardware configuration ENC n=1 sr= 1 pins=0:1 type=detented1 # Events EVENT_ENC id=1 fwd_id=881 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range=0:127 lcd_pos=1:1:1 label="^std_enc" fwd_id can be anything you don't already use... this sample = 881 Regards, Novski
Keeze Posted February 6, 2016 Author Posted February 6, 2016 Hello Novski, Tnx for your reply! I added the suggested fwd_id, but than the program stucks saying: [11261.264] AUTOLOAD 'ENC' [11261.264] [MBNG_FILE_C:6] ERROR: invalid fwd_id controller name in EVENT_ENC ... fwd_id=123 [11261.264] [MBNG_FILE_C] Event Pool Number of Items: 0 [11261.264] [MBNG_FILE_C] Event Pool Allocation: 12 of 65536 bytes (0%) [11261.275] Patch 'ENC' loaded from SD Card! [11261.278] [MBNG_FILE_R] /ENC.NGR (optional run script) not found Cheers, Kees
Keeze Posted February 7, 2016 Author Posted February 7, 2016 I could be completely wrong (I am not a C-coder), but in lines 233 - 247 of mbng_enc.c I find: s32 value = item.value; if( item.min <= item.max ) { value = event_incrementer; if( value < item.min ) value = item.min; else if( value > item.max ) value = item.max; } else { // reversed range value = event_incrementer; if( value < item.max ) value = item.max; else if( value > item.min ) value = item.min; } so value is replaced by event_incrementer and not added? Or am I completely wrong... value = event_incrementer; vs value += event_incrementer; ... Digging further.. Kees
TK. Posted February 7, 2016 Posted February 7, 2016 Good find, thanks for the information! :) This bug came in with the changes for interpolation maps. It's fixed in this pre-release: http://www.ucapps.de/mios32/midibox_ng_v1_035_pre2.zip Could you please check if it works at your side? Then I will publish the "final v1.035" at my webpage Best Regards, Thorsten.
Keeze Posted February 7, 2016 Author Posted February 7, 2016 Hi Thorsten, I confirm that this issue is solved! All works great, a big thanks from Holland! :-) Keep up the good work! Cheers, Kees
TK. Posted February 8, 2016 Posted February 8, 2016 Great! :) V1.035 is now officially released. Best Regards, Thorsten.
