Keeze Posted April 1, 2016 Report Posted April 1, 2016 Hi all, In the schematic for the Quad IIC Midi board, I find 15pF caps for running the crystal. I have only 22pF laying around (and used to use these with 16/20 Mhz crystals). Is there a specific reason to use 15pF or would 22pF do? Cheers, Kees
latigid on Posted April 1, 2016 Report Posted April 1, 2016 I would hazard a guess that the caps are 20% or worse tolerance anyway? Have a go I say.
Keeze Posted April 1, 2016 Author Report Posted April 1, 2016 That were my thoughts to, but always worth to check, tnx ;)
CJ55 Posted April 1, 2016 Report Posted April 1, 2016 The value of the caps depends also on the crystal/quartz. Some need 18pF, other 32pF for example. Check the data sheet of the crystal/quartz you are using. 1
Keeze Posted April 1, 2016 Author Report Posted April 1, 2016 Found the datasheet... 10 to 32 pF, so 22 should do the trick
