ModularLove Posted August 31, 2016 Posted August 31, 2016 Hello there, I got this attractive machine recently as a broken item but was able to "fix" it buy using a Euro 220v step up box. So it works great booting up MIOS v 1.9. But I have trouble understanding how to save and recall patches. I can change the names of the knob settings and change the names of the banks but when i go to select patch the display just reads " < new patch A1 >" on the first line of the display and the second line reads "Not in Patchmode" Now effectively I can get by and use each of the 16 external banks as an individual patch but I would like to take full advantage of the potential of this MIDIBOX64 or ...........(possibly) MIDIBOX64e? Thank you for any help. S
latigid on Posted August 31, 2016 Posted August 31, 2016 Are any Banksticks installed? http://www.ucapps.de/mbhp_bankstick.html Judging from the wiring it's probably an MB64E. You could upgrade to a 32-bit Core, then the configuration and patch storage is easily done with SD cards.
ModularLove Posted August 31, 2016 Author Posted August 31, 2016 (edited) It does have one bankstick installed. The chip is wrapped in electrical tape in the lower righthand of the photo that shows inside. Hard to see. my needs are simple since i am going to use this to control just two or three synths together, but would upgrading to a 32 bit core require anything more than a new main chip and a new flash of firmware? Edited August 31, 2016 by ModularLove
latigid on Posted August 31, 2016 Posted August 31, 2016 It could be a connection problem or it might just need configuration. Have a look here for the info:http://www.ucapps.de/midibox16e.html I don't know how familiar you are with electronics/MIDIbox etc., but what you have is a grid of panel mounted encoders and switches, which are scanned by shift register "modules" stuffed with 74HC165 chips. These form the SRIO chain. The Core is the brain of the operation, and newer generations are not only backwards compatible and easier to configure, but are faster and offer more hardware options (increased MIDI IO, USB, OSC/Ethernet, SD storage, etc.). It's a whole new board though:http://www.ucapps.de/mbhp_core_stm32f4.html
ModularLove Posted August 31, 2016 Author Posted August 31, 2016 (edited) I have been reading up on the whole MidiBox thing for around a week and also had some help from some wonderful people in the FB Budget Gear forum. But I am having a little trouble getting a clear idea of the full process and things like 64 vs 64e. I can do some repair soldering but I am a rank beginner on breadboarding out things so the 32 bit upgrade looks to be beyond me for now. As it is, I think the only improvements I am looking to do are possibly a couple extra midi outs and maybe installing an Axoloti synth board inside if I can figure out some way to drill the holes without it looking like crap. (not enough room in the back) Edited August 31, 2016 by ModularLove
ModularLove Posted August 31, 2016 Author Posted August 31, 2016 (edited) I noticed that the Midibox64e tutorial doesn't even mention a patch select mode or that it comes after the bank select. But I did find this in the changelog. "V2.2 a patch mode has been implemented which can be selected as an alternative option to the common "bank" mode in main.asm In patch mode, each BankStick contains only one bank configuration (means: encoder/pot/button/label setup), but 128 snapshots! This allows you to prepare one configuration for your MIDI gear, and to store/recall/morph up to 128 scenes. there are two new SysEx commands for storing/restoring patches patches and banks can be changed from external with a "Program Change" command. The channels are specified in main.asm. Default: Channel 16 - Banks; Channel 15: Patches" Looks like I may be in a mode where there is all snapshots....but i don't seem to be able to recall or scroll through those snapshots so maybe not. Edited August 31, 2016 by ModularLove
latigid on Posted August 31, 2016 Posted August 31, 2016 http://midiboxshop.bigcartel.com/product/core-stm32f4-board-kit No need to breadboard. IMO this is almost the simplest MBHP to build and there's very little to go wrong. Maybe see how you go with the 8-bit and if it's too hard consider a Core upgrade as a solution. Good luck!
latigid on Posted August 31, 2016 Posted August 31, 2016 http://www.ucapps.de/mios_download.html If the setup's too confusing you might consider a fresh install using MIOS Studio and the MIDI ports. Sometimes TK. will configure different hex files, otherwise you need to edit the .asm and recompile.
Shuriken Posted September 4, 2016 Posted September 4, 2016 Just a little comment about the transformer. I guess you are located in the US. So you could replace it with a transformer which is suited for 115V. This would have been a cheaper option, but i guess that ship has sailed. Second problem i see is that the transformer has two secondaries, but only one is used. This is not good. My suggestion would be to fix this by doing this: Not sure if there are any fuses (i cannot see the mains connector) but if you want to make it safe(!) make sure the main side included a fuse.
