FantomXR Posted November 9, 2017 Report Posted November 9, 2017 Hey people, I have two questions regarding the WS2812. If you read through the internet you will find various articles that one should use a resistor between DIN of the LED and the output-pin of the microcontroller. Is that also right for the STM32F4? The second thing is, that the first (or sometimes an other) LED lights up short after a few seconds after powering the core (both share the same power supply). Any ideas how to prevent this? Thanks, Chris
TK. Posted November 9, 2017 Report Posted November 9, 2017 Hi Chris, adding a resistor (e.g. 470 Ohm) to between the core output pin and WS2812 is probably a good idea, see this posting for the arguments: https://electronics.stackexchange.com/questions/177019/why-does-a-resistor-in-my-neopixel-data-line-work-at-all The LED should turn off once the Core starts to drive data into the chain. Enable the "fastboot" option so that this happens as fast as possible Best Regards, Thorsten.
FantomXR Posted November 10, 2017 Author Report Posted November 10, 2017 Dear TK, thanks for your reply. Alright, I'll add this resistor. For the other "problem" I'll try to add a hardware delay with RC circuit to prevent the LED from flashing.
