I'm having trouble getting leds to work properly with pro tools
At the moment I have the leds responding when I press solo in pro tools, but the problem is, when I press solo on any channel it will turn on all leds I have assigned. I know that the problem is in the way I'm coding because it is only doing this in pro tools.
The code I am using is this, which are the cc equivalent values to sysex zone select/port on:
EVENT_LED id=  1 type=cc chn=1 cc=12 range=0:0
EVENT_LED id=  1 type=cc chn=1 cc=44 range=67:67
I can't get them to respond with sysex messages, whereas it does work for buttons. For example, this was not working:
EVENT_LED id= 1  type=sysex stream="0xb0 0x0c 0x00 0xb0 0x2c 0x43"
I have the buttons configured in a similar way as shown before with cc messages with ranges and they work, so I thought maybe this could work for the leds, but it appears that is wrong
What would be the right way to do this?
Posted (edited)
Hello 2hb
I guess you try to set all this in HUI mode (which is not sysex !! )
I have an beta/optional NGC/NGR version for a control surface in HUI mode.
I'll check it and share the code strategy for this purpose asap, it's tricky...
Best
Zam
Edited by Zam
Ok, here it is.
Example for SOLO function, hw_id related to my DI/O layout so you have to adapt...
# SOLO 1-8
EVENT_BUTTON  hw_id=4   id=4   type=SySEx  stream="0xb0 0x0f 0x00 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=12  id=12  type=SySEx  stream="0xb0 0x0f 0x01 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=20  id=20  type=SySEx  stream="0xb0 0x0f 0x02 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=28  id=28  type=SySEx  stream="0xb0 0x0f 0x03 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=36  id=36  type=SySEx  stream="0xb0 0x0f 0x04 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=44  id=44  type=SySEx  stream="0xb0 0x0f 0x05 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=52  id=52  type=SySEx  stream="0xb0 0x0f 0x06 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_BUTTON  hw_id=60  id=60  type=SySEx  stream="0xb0 0x0f 0x07 0xb0 0x2f 0x43"  button_mode=toggle
EVENT_RECEIVER  hw_id=1040  id=1040  type=cc  chn=1  cc=0x0c
EVENT_RECEIVER  hw_id=1041  id=1041  fwd_id=sender:1040:127  type=cc  chn=1  cc=0x2c  if_equal=0x43
EVENT_RECEIVER  hw_id=1042  id=1042  fwd_id=sender:1040:0    type=cc  chn=1  cc=0x2c  if_equal=0x03
EVENT_SENDER    hw_id=1040  id=1040  fwd_id=led:4
EVENT_LED   hw_id=4   id=4   if_equal=receiver:1040:0
EVENT_SENDER    hw_id=1040  id=1041  fwd_id=led:12
EVENT_LED   hw_id=12  id=12   if_equal=receiver:1040:1
EVENT_SENDER    hw_id=1040  id=1042  fwd_id=led:20
EVENT_LED   hw_id=20  id=20   if_equal=receiver:1040:2
EVENT_SENDER    hw_id=1040  id=1043  fwd_id=led:28
EVENT_LED   hw_id=28  id=28   if_equal=receiver:1040:3
EVENT_SENDER    hw_id=1040  id=1044  fwd_id=led:36
EVENT_LED   hw_id=36  id=36   if_equal=receiver:1040:4
EVENT_SENDER    hw_id=1040  id=1045  fwd_id=led:44
EVENT_LED   hw_id=44  id=44   if_equal=receiver:1040:5
EVENT_SENDER    hw_id=1040  id=1046  fwd_id=led:52
EVENT_LED   hw_id=52  id=52   if_equal=receiver:1040:6
EVENT_SENDER    hw_id=1040  id=1047  fwd_id=led:60
EVENT_LED   hw_id=60  id=60   if_equal=receiver:1040:7
Best
Zam
For button, Sysex trick only one way, MIOS can send it but not receive it.
For led, all them triggered by value (on/off with formatting) and activated only if zone value match
Best
Zam
Thank you!! It is all working now!
I guess as a side note, do you think there could be a way to make the mutes not flash when you solo a channel?
Yes should be possible, certainly different options, with conditional at NGC, or set_active at NGR.
However you have to think it a little further as you may have domino effect with the mute function if you just do a basic logic
You have to define situation you don't want the flash without locking the mute LED for simultaneous state you need a mute...
Best
Zam
