oozitron Posted January 5, 2019 Report Posted January 5, 2019 I would like to have the F1~ F4 buttons jump me to the Events, Direction, Divider & Length screens (directly with just a single button press, instead of pressing MENU + GP buttons) I edited the HWConfig file (see BOLDFACED below), saved and restarted, but the F buttons now do nothing. Is it possible to do what I want? If so what am I doing wrong? thanks for any help, Andrew # Following button functions are usually assigned to Fx # buttons, or to dedicated (labeled) buttons # In Wilba's frontpanel layout: # F1 is located at SR M3 Pin 3 # F2 is located at SR M2 Pin 2 # F3 is located at SR M2 Pin 3 # F4 is located at SR M1 Pin 2 # and there are dedicated buttons for Copy/Paste/Clear/Utility/StepView # SR Pin EVENTS M3 3 DIRECTION M2 2 DIVIDER M2 3 LENGTH M1 2
TK. Posted January 5, 2019 Report Posted January 5, 2019 Hi Andrew, these button assignments don't exist, you should get an error message while the file is read (btw.: no need to reset the device, the file will be parsed automatically after upload). You could assign F1..F4 to BUTTON_DIRECT_BOOKMARK1 .. 4 instead. Please do this assignment at the prepared placeholders (which are assigned to 0 0 by default), otherwise they could overwrite your change. Once done, edit the MBSEQ_BM.V4 file: set for Slot1: +Page EVENTS Slot2: +Page DIRECTION Slot3: +Page DIVIDER Slot4: +Page LENGTH In these slots, also change the remaining "+" parameters to "-" (so that the values won't be taken over when you are pressing a bookmark button) Best Regards, Thorsten.
