electrodancer Posted March 29, 2019 Posted March 29, 2019 hi there...ive build the seq v4+ but now i can not get the CV (from Aout-ng) and GATES and CLOCKS (from dout board) working i have the (new) linedriver transmitter inside the seqV4+ and i have the (old) lindriver receiver on the other end of the cable i have a Aout-ng board and a doutx4 connected to the receiver (clocks, gates and cv were working on my (old) seqv4...now im trying to get this working with my new seqv4+ what ive tried: inspect the linedriver module set the si jumper on the lindriver transmitter (it is there on my old seqv4) set the correct Aout board in the menu ive tried to assign the shiftregisters to the same numbers and pins in the hw-file as i did with my old seqv4....but this gives only messed up leds. can some one help me with this ?
slo Posted March 29, 2019 Posted March 29, 2019 You need to assign them to new numbers, the old SeqV4 ones won't work, see Andy's reply to the same question half way down this page Link
electrodancer Posted March 29, 2019 Author Posted March 29, 2019 thanks ...that makes sense ive followed up on the link....and set the shift registers but still no cv gate or clock also the led on the Aout-ng does nog light up when i connect the seqv4+ (and it does light up when i connect the seqv4) so i think there is no power over the 25 pin cable ?.. cheers Vincent
electrodancer Posted March 30, 2019 Author Posted March 30, 2019 solved....it was a missing jumper on de linedriver transmitter board
