dotmod Posted April 25, 2019 Posted April 25, 2019 Hello. I have a problem with the DIN module. After starting the whole set in configuration: - Core R4D, SID R3A, DINX4, LCD 2x20, mios 1.9g, PIC 18F452 and 4620 tested and different pcb-s - Connections according to the scheme: MIDIbox SID V2 CS DIN map) as a attached jpg the "select 1-5" buttons and encoder menu works fine. The "menu" button works like a "back" button. But the "Up / CC", "Down / Edit" and "Shift" buttons don`t work :( Where is the problem, what I'm doing wrong ? Please help :(
Noise-Generator Posted May 8, 2019 Posted May 8, 2019 18f452 is for sid v1 Have you checked if all connections are good? If you use more than one dinx than built one more and check again. 1
dotmod Posted May 12, 2019 Author Posted May 12, 2019 I checked twice, I have a second DIN module and have the same issue. Many years ago, when I build this setup , all worked fine.
Noise-Generator Posted May 26, 2019 Posted May 26, 2019 It is normal that the Menu behaves like a "back" or more like an "escape" key. I don't know why the others won't work.
