hi!! i have just finished my midibox 64,but it usually give me this error : "Midi time out. Wassup??" that happens when i try to upload a Syx file...but not always....what is happening?? all conections in the core are ok,and midi out of midibox goes fine....please answer me!!
thanks!!
Lower the rate youre sending the sysex. The standard value is (I think) 400 bytes/second, which is a little to much for MIOS 1.4 (will be better with MIOS 1.5 as it will react a little faster I think). I had good experiences with values around 250 bytes / second.
ok...but in midiox program...where can i change that rate value?
i have tried upload mios v1.5,but after midibox says Rebooting,it says Mios.V1.4......whats happening?
i have tried with virtual midibox...but i cant send sysex unless i deactivate midi merger on midibox....ok..i click on send sysex comand on screen...lcd say receiving sysex dump...but it stops suddendly before the program stops sending the sysex!
i cant found the fail...please..help me..
thanks
heya!
problems solved!
ther was a wire doing a false conection!!
and the first error,midi time out,has been solved setting  the download rate of vmidibox to 120 bytes/s.
thanks Pay_c and Thorsten!!
;D
