Hello,
I recently built a sammichSID Midibox & am having issues with the firmware. I am uploading the most recent version of the hex file (midibox_sid_v2_044/setup_sammich_sid.hex) & every time it's uploaded, I receive ignorable errors in MIOS Studio (see attached image). Also, the prompt says the "Bootloader is up & running" afterward & never changes to "Application is up & running" (unless that only happens when no ignorable errors are detected...?).
Can anyone give me any hints or point me in the right direction? Thanks in advance.
  • 6 months later...
Started a sammichSID build many years ago. Everything was fine up to the point where the file uploading partially failed. Was never able to figure it out. Similar situation, was also using MIOS Studio (OSX) at the time.
Curios to know what the solution was in your case?
Thanks.
