Karg Posted February 23, 2020 Posted February 23, 2020 Good morning, by any chance, does someone know a good alternative to the ALPS STEC12E08 rotary encoder which is panel mountable (thread + screw), but with similar properties (durability, steps, switch, etc)? I tried checking directly on the Alps homepage, but was lost in all their versions sooo quickly... Thanks a lot in advance. Best, Karg
FantomXR Posted February 23, 2020 Posted February 23, 2020 Check bourns encoder. You can find their stuff in mouser. And mouser has a pretty good filter / search engine.
Karg Posted February 23, 2020 Author Posted February 23, 2020 Thanks! That was just the small push into the right direction I needed...
