Againsistm Posted May 18, 2020 Posted May 18, 2020 Hi all, Hope you are all doing ok! I just finalized building a tr-9090 and are sequencing it with a Midiphy. Everything works as expected. What i can't find is when you create a drum track and connect via midi. How does a trigger work sent from the midibox? A 909 except a 2ms trigger but i cant find anything how long a trigger is sent via midi? Is this adjustable? Thanks!! Niels
Antichambre Posted May 18, 2020 Posted May 18, 2020 (edited) Not sure for a 9090 but generally a drum sound has no sustain and triggers on NoteOn, Note duration does not matter, but NoteOff must be received between 5 and 10ms after, just to permit the same NoteOn to be received again. Edited May 18, 2020 by Antichambre
Againsistm Posted May 19, 2020 Author Posted May 19, 2020 Thanks now i understand.. The 9090 has internal triggers for each drum but the note on will be converted to a 2ms trigger by the 9090 midi implementation. Thanks! Cheers Niels
