ganchan Posted June 6, 2020 Posted June 6, 2020 Hello, i'm switching to OLED on my SammichSID and SammichFM but i can't find anything like the pin header that went with the kits, maybe the base was pushed up to make the base pin longer, my local store doesn't have anything like that and on mouser or digikey i really can't find it, i'm asking for suggestion so. I've attached a photo. Cheers. G.
latigid on Posted June 6, 2020 Posted June 6, 2020 Mouser 517-929834-07-36-RK is one of the longest "standard" headers but only single row. Check the datasheet on the Mouser page and you will find other parts. None of the longer dual-row header 929710 are stocked apparently. But you could use a pair of single-row strips, which is what we do for the LoopA. 2
ganchan Posted June 7, 2020 Author Posted June 7, 2020 Thank you very much i'll look into that straight way! G.
