imaginarion Posted March 17, 2021 Posted March 17, 2021 (edited) Hello everybody! Is it possible to integrate a generator into Midibox SID v2 SAM? If I understood correctly, then Comodore had these algorithms inside of them. It would be great to be able to do hardware synthesis like in the original compdore https://github.com/s-macke/SAM Edited March 17, 2021 by imaginarion
Antichambre Posted March 17, 2021 Posted March 17, 2021 SAM is an independant program, no need of a SID, the SID was used on C64 as DAC. But it was working on Apple, Atari etc... But good news it's a C source code you can embed onto a MIDIbox Core, you just need a DAC, an audio output.
imaginarion Posted March 17, 2021 Author Posted March 17, 2021 thanks for the answer! I'm afraid it's not in my power to work with code. Maybe one day someone wants to make a 5th speech engine for MiOS
imaginarion Posted March 17, 2021 Author Posted March 17, 2021 If anyone has the opportunity to suggest in which file I can put Sam's code so that I can try to do something with it further, it would be great!
Antichambre Posted March 18, 2021 Posted March 18, 2021 I had a look on the code, it's more complicated than just add some SAM files. You will need to understand an maybe adapt/modify the necessary parts(files) and create Input/Output interfacing, check ram memory needed etc... For us it must be realtime process... But as a start: For input the easiest first way is to use MIOS-Studio Terminal for SAM commands, and output wave file to the SD card. It's not real-time but just an example. Something like that: [28337.121] SD Card status 1 [28339.122] SD Card status 3 [28339.122] SD Card CONNECTED [28342.433] help [28342.435] Welcome to the HAARP Terminal! [28342.435] Following commands are available: [28342.435] sam_usage: SAM Usage [28342.435] sam: SAM [28342.435] reset: resets the MIDIbox (!) [28342.435] help: this page [28345.225] sam_usage [28345.227] usage: sam [options] Word1 Word2 .... [28345.227] options [28345.227] -phonetic enters phonetic mode. (see below) [28345.227] -pitch number set pitch value (default=64) [28345.227] -speed number set speed value (default=72) [28345.227] -throat number set throat value (default=128) [28345.227] -mouth number set mouth value (default=128) [28345.227] -wav filename output to wav instead of libsdl [28345.228] -sing special treatment of pitch [28345.228] -debug print additional debug messages [28345.228] [28345.228] VOWELS VOICED CONSONANTS [28345.228] IY f(ee)t R red [28345.228] IH p(i)n L allow [28345.228] EH beg W away [28345.228] AE Sam W whale [28345.228] AA pot Y you [28345.228] AH b(u)dget M Sam [28345.228] AO t(al)k N man [28345.229] OH cone NX so(ng) [28345.229] UH book B bad [28345.229] UX l(oo)t D dog [28345.229] ER bird G again [28345.229] AX gall(o)n J judge [28345.229] IX dig(i)t Z zoo [28345.229] ZH plea(s)ure [28345.229] DIPHTHONGS V seven [28345.229] EY m(a)de DH (th)en [28345.230] AY h(igh) [28345.230] OY boy [28345.230] AW h(ow) UNVOICED CONSONANTS [28345.230] OW slow S Sam [28345.230] UW crew Sh fish [28345.230] F fish [28345.230] TH thin [28345.230] SPECIAL PHONEMES P poke [28345.230] UL sett(le) (=AXL) T talk [28345.230] UM astron(omy) (=AXM) K cake [28345.231] UN functi(on) (=AXN) CH speech [28345.232] Q kitt-en (glottal stop) /H a(h)ead [28359.145] sam -debug -pitch 64 -speed 128 -mouth 128 -wav TEST_OK midibox sam is great! [28359.147] text input: MIDIBOX SAM IS GREAT! [28359.147] Applying rule: [28359.147] ( [28359.147] M [28359.147] ) [28359.147] -> [28359.147] M [28359.147] [28359.147] Applying rule: [28359.147] ( [28359.147] I [28359.147] ) [28359.147] ^ [28359.148] + [28359.148] : [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] D [28359.148] ) [28359.148] -> [28359.148] D [28359.148] [28359.148] Applying rule: [28359.148] I [28359.148] ^ [28359.148] ( [28359.148] I [28359.148] ) [28359.148] ^ [28359.148] # [28359.148] -> [28359.148] I [28359.148] H [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] B [28359.148] ) [28359.148] -> [28359.148] B [28359.148] [28359.148] Applying rule: [28359.148] ( [28359.148] O [28359.148] ) [28359.148] -> [28359.148] A [28359.148] A [28359.148] [28359.149] Applying rule: [28359.149] ( [28359.149] X [28359.149] ) [28359.149] -> [28359.149] K [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] S [28359.149] ) [28359.149] -> [28359.149] S [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] A [28359.149] ) [28359.149] -> [28359.149] A [28359.149] E [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] M [28359.149] ) [28359.149] -> [28359.149] M [28359.149] [28359.149] Applying rule: [28359.149] ( [28359.149] I [28359.149] ) [28359.149] -> [28359.149] I [28359.149] H [28359.149] [28359.149] Applying rule: [28359.149] [28359.149] : [28359.149] # [28359.149] ( [28359.149] S [28359.150] ) [28359.150] [28359.150] -> [28359.150] Z [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] G [28359.150] R [28359.150] E [28359.150] A [28359.150] T [28359.150] ) [28359.150] -> [28359.150] G [28359.150] R [28359.150] E [28359.150] Y [28359.150] 4 [28359.150] T [28359.150] [28359.150] Applying rule: [28359.150] ( [28359.150] ! [28359.150] ) [28359.150] -> [28359.150] . [28359.150] [28359.150] phonetic input: MIHDIHBAAKS SAEM IHZ GREY4T. � [28359.150] =========================================== [28359.150] Internal Phoneme presentation: [28359.150] idx phoneme length stress [28359.150] ------------------------------ [28359.151] 0 * 0 0 [28359.151] 27 M* 0 0 [28359.151] 6 IH 0 0 [28359.151] 57 D* 0 0 [28359.151] 6 IH 0 0 [28359.151] 54 B* 0 0 [28359.151] 9 AA 0 0 [28359.151] 72 K* 0 0 [28359.151] 32 S* 0 0 [28359.151] 0 * 0 0 [28359.151] 32 S* 0 0 [28359.151] 8 AE 0 0 [28359.151] 27 M* 0 0 [28359.151] 0 * 0 0 [28359.151] 6 IH 0 0 [28359.152] 38 Z* 0 0 [28359.152] 0 * 0 0 [28359.152] 60 G* 0 0 [28359.152] 23 R* 0 0 [28359.152] 48 EY 0 4 [28359.152] 69 T* 0 0 [28359.152] 1 .* 0 0 [28359.152] 0 * 0 0 [28359.154] =========================================== [28359.154] [28359.154] Parser2 [28359.154] 0: * [28359.154] 1: M* [28359.154] 2: IH [28359.154] 3: D* [28359.154] RULE: Soften T or D following vowel or ER and preceding a pause -> DX [28359.154] 4: IH [28359.154] 5: B* [28359.154] 6: AA [28359.154] 7: K* [28359.154] RULE: K <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> KX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 8: S* [28359.154] 9: * [28359.154] 10: S* [28359.154] 11: AE [28359.154] 12: M* [28359.154] 13: * [28359.154] 14: IH [28359.154] 15: Z* [28359.154] 16: * [28359.154] 17: G* [28359.154] RULE: G <VOWEL OR DIPTHONG NOT ENDING WITH IY> -> GX <VOWEL OR DIPTHONG NOT ENDING WITH IY> [28359.154] 18: R* [28359.154] 19: EY [28359.154] RULE: insert YX following dipthong ending in IY sound [28359.154] 20: YX [28359.154] 21: T* [28359.154] 22: .* [28359.154] 23: * [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 20 (YX) length 8 [28359.154] POST [28359.154] phoneme 20 (YX) length 13 [28359.154] RULE: Lengthen <FRICATIVE> or <VOICED> between <VOWEL> and <PUNCTUATION> by 1.5 [28359.154] PRE [28359.154] phoneme 21 (T*) length 4 [28359.154] POST [28359.154] phoneme 21 (T*) length 7 [28359.154] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.154] PRE [28359.154] phoneme 3 (DX) length 2 [28359.154] POST [28359.154] phoneme 4 (IH) length 11 [28359.154] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.155] PRE [28359.155] phoneme 6 (AA) length 11 [28359.155] POST [28359.155] phoneme 6 (AA) length 10 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 10 (S*) length 2 [28359.155] POST [28359.155] phoneme 11 (AE) length 11 [28359.155] RULE: <VOWEL> <VOICED CONSONANT> - increase vowel by 1/2 + 1 [28359.155] PRE [28359.155] phoneme 13 ( *) length 0 [28359.155] POST [28359.155] phoneme 14 (IH) length 11 [28359.155] RULE: <LIQUID CONSONANT> <DIPTHONG> - decrease by 2 [28359.155] PRE [28359.155] phoneme 18 (R*) length 10 [28359.155] POST [28359.155] phoneme 18 (R*) length 8 [28359.156] RULE: <VOWEL> <UNVOICED PLOSIVE> - decrease vowel by 1/8th [28359.156] PRE [28359.156] phoneme 20 (YX) length 13 [28359.156] POST [28359.156] phoneme 20 (YX) length 12 [28359.156] =========================================== [28359.156] Internal Phoneme presentation: [28359.156] idx phoneme length stress [28359.156] ------------------------------ [28359.156] 0 * 0 0 [28359.156] 27 M* 7 0 [28359.156] 6 IH 8 0 [28359.156] 30 DX 2 0 [28359.156] 6 IH 11 0 [28359.156] 54 B* 6 0 [28359.157] 55 ** 1 0 [28359.157] 56 ** 2 0 [28359.157] 9 AA 10 0 [28359.157] 75 KX 6 0 [28359.157] 76 ** 1 0 [28359.157] 77 ** 4 0 [28359.157] 32 S* 2 0 [28359.157] 0 * 0 0 [28359.157] 32 S* 2 0 [28359.157] 8 AE 11 0 [28359.157] 27 M* 7 0 [28359.157] 0 * 0 0 [28359.157] 6 IH 11 0 [28359.157] 38 Z* 6 0 [28359.157] 0 * 0 0 [28359.158] 63 GX 6 0 [28359.158] 64 ** 1 0 [28359.158] 65 ** 2 0 [28359.158] 23 R* 8 5 [28359.158] 48 EY 14 4 [28359.158] 21 YX 12 4 [28359.158] 69 T* 7 0 [28359.158] 70 ** 2 0 [28359.158] 71 ** 2 0 [28359.158] 1 .* 18 0 [28359.158] 254 ?? 0 [28359.158] 0 * 0 0 [28359.158] =========================================== [28359.158] [28359.159] =========================================== [28359.159] Final data for speech output: [28359.159] flags ampl1 freq1 ampl2 freq2 ampl3 freq3 pitch [28359.159] ------------------------------------------------ [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.159] 0 9 6 2 46 0 81 61 [28359.160] 0 9 6 2 46 0 81 61 [28359.160] 0 9 10 4 59 2 87 59 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 11 14 8 72 4 93 57 [28359.160] 0 23 96 23 151 29 102 16 [28359.160] 0 44 179 6 230 6 111 231 [28359.161] 0 0 6 0 54 0 121 61 [28359.161] 0 2 8 2 60 2 197 60 [28359.161] 0 4 11 4 66 2 17 59 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.161] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 11 14 8 72 4 93 57 [28359.162] 0 26 76 29 124 2 154 26 [28359.162] 0 9 138 14 177 6 215 251 [28359.162] 0 36 200 30 229 36 20 220 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 0 26 0 81 61 [28359.162] 0 2 6 1 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.162] 0 0 6 0 26 0 81 61 [28359.163] 0 3 12 2 30 0 83 58 [28359.163] 0 6 19 4 35 0 86 55 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 15 26 11 40 1 89 51 [28359.163] 0 20 65 30 47 8 89 32 [28359.164] 0 23 104 23 54 23 90 12 [28359.164] 0 9 144 16 62 17 91 248 [28359.164] 0 44 183 44 69 10 92 229 [28359.164] 0 51 222 51 76 73 93 209 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.164] 0 0 6 6 84 3 94 61 [28359.164] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 84 0 94 61 [28359.165] 0 0 6 0 133 0 95 61 [28359.165] 241 0 6 0 182 0 96 61 [28359.165] 241 0 6 0 231 0 97 61 [28359.165] 241 0 6 0 24 0 98 61 [28359.165] 241 0 6 0 73 0 99 61 [28359.166] 0 2 10 2 134 2 160 59 [28359.166] 0 4 15 4 195 2 221 57 [28359.166] 0 8 19 6 0 3 26 55 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.166] 0 15 24 13 62 4 88 52 [28359.167] 0 15 24 13 62 4 88 52 [28359.167] 0 6 143 10 182 6 212 249 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.167] 0 9 6 2 46 0 81 61 [28359.168] 0 9 6 2 46 0 81 61 [28359.168] 0 9 10 4 59 2 87 59 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 11 14 8 72 4 93 57 [28359.168] 0 29 64 23 119 20 93 32 [28359.169] 0 18 114 20 166 26 93 7 [28359.169] 1 6 164 6 213 6 93 238 [28359.169] 1 66 214 73 4 86 93 213 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 8 9 2 51 0 93 60 [28359.169] 1 29 72 2 59 0 93 28 [28359.169] 0 16 135 6 67 0 93 253 [28359.169] 0 50 198 48 75 0 93 221 [28359.169] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 1 6 0 84 0 94 61 [28359.170] 0 2 6 1 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 0 6 0 84 0 94 61 [28359.170] 0 2 9 2 139 1 149 109 [28359.170] 0 3 12 3 195 2 205 157 [28359.170] 0 5 15 4 250 2 4 206 [28359.170] 0 9 18 6 50 3 60 254 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 50 3 60 48 [28359.171] 0 9 18 6 54 3 66 70 [28359.171] 0 9 18 8 58 3 72 93 [28359.171] 0 11 18 9 63 4 78 116 [28359.171] 0 11 18 11 67 4 84 139 [28359.171] 0 13 18 13 72 5 90 162 [28359.171] 0 13 18 13 72 5 90 184 [28359.171] 0 13 18 13 72 5 90 207 [28359.172] 0 13 18 13 72 5 90 230 [28359.172] 0 13 18 13 72 5 90 253 [28359.172] 0 13 18 13 72 5 90 20 [28359.172] 0 13 18 13 72 5 90 45 [28359.172] 0 13 18 13 72 5 90 46 [28359.172] 0 13 49 8 103 10 90 35 [28359.172] 0 13 81 26 135 29 90 24 [28359.172] 0 13 112 16 166 18 91 12 [28359.172] 0 13 144 6 198 10 91 1 [28359.172] 0 13 175 6 229 6 91 246 [28359.173] 0 13 207 46 5 24 92 235 [28359.173] 0 13 238 66 36 26 92 223 [28359.173] 0 13 14 9 68 4 93 84 [28359.173] 0 13 14 9 68 4 93 88 [28359.173] 0 13 14 9 68 4 93 93 [28359.173] 0 13 14 9 68 4 93 97 [28359.173] 0 13 14 9 68 4 93 102 [28359.173] 0 13 14 9 68 4 93 61 [28359.173] 0 13 14 9 68 4 93 62 [28359.173] 0 26 76 27 131 2 100 56 [28359.173] 0 9 138 16 195 6 107 51 [28359.174] 0 50 200 50 2 36 114 45 [28359.174] 0 0 6 0 66 0 121 168 [28359.174] 0 0 6 0 66 0 121 193 [28359.174] 0 0 6 0 66 0 121 219 [28359.174] 0 0 6 0 66 0 121 244 [28359.175] 0 0 6 0 66 0 121 14 [28359.175] 25 0 6 0 66 0 121 75 [28359.175] 25 0 6 0 66 0 121 76 [28359.175] 0 0 6 0 66 0 121 77 [28359.175] 0 0 9 0 66 0 177 99 [28359.176] 0 0 12 0 66 0 234 121 [28359.176] 0 0 15 0 66 0 34 144 [28359.176] 0 0 19 0 67 0 91 166 [28359.176] 0 0 19 0 67 0 91 190 [28359.176] 0 0 19 0 67 0 91 214 [28359.176] 0 0 19 0 67 0 91 238 [28359.176] 0 0 19 0 67 0 91 6 [28359.176] 0 0 19 0 67 0 91 30 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 19 0 67 0 91 55 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.176] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.177] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.178] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.179] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.180] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.181] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.182] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.183] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.184] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] 0 0 0 0 0 0 0 0 [28359.185] =========================================== [28359.526] TEST_OK.WAV saved 1
Antichambre Posted March 18, 2021 Posted March 18, 2021 (edited) Open a new thread in user's project please, named MIDIbox SAM, a MIDI speeching box... something like that. I will share what I did in it... Edited March 19, 2021 by Antichambre
