Hello Thorsten,
while planning (layouting) my (next) MIDIbox LC I recognized a error in the layout of the MBHP_DOUT_MTC.
Both files, mbhp_dout_mtc_v1.brd and .gif contains it.
The error: The 220 resistors which have to be connected to pin 15 of the two 74HC595 are routed to +5V.
I tried to correct it. But I'm not practised in EAGLE at all !! (I use other layout software). So can you please check the two connections I've changed and place the correct layouts in ucapps ?
Heres the changed file:
http://www.systemhaus-schneider.de/doc/mbhp_dout_mtc_v1a.brd
Thanks and greetings.
DOC
Thank you Thorsten for the pdf.
Before posting my 'changed' layout could you please 'inspect' the changed tracks. I wasn't able to get them "round". (As mentioned before...I'm a EAGLE dummy  :P)
Thank you
Doc
